Has anyone had good or bad luck with the Ididit steering column replacement. I need a tilt wheel.
. Recommendations please...I do like Ididit however there are several models. Any other brands?
What year do you have? I ordered an IDIDIT cut to the length for my borgeson box. I went with them because they have a 67 column that resembles the original. Also went with a C3 wheel as it is a hair smaller and shallower.
I have a IdidIt column . It was one of the best things I did for the car. I can get in and out without a problem.
I do run a 15 in steering wheel. Not hard to install. I am a big man and before I made the changes it was
difficult getting in and out plus it is a very comfortable to drive with the new IdidIt column.
You wont be disapointed with a adjustable steering column.
Good luck
