[C2] 63 electroic ign. install
Old Apr 13, 2024 | 07:44 PM
prestige6's Avatar
prestige6
Default 63 electroic ign. install
I'm installing an electronic ignition. in my 63. Has two leads, do I need to connect to my ballast resistor or can I just connect it to the coil???
Old Apr 13, 2024 | 08:17 PM
bauto's Avatar
bauto
Your instructions should tell if it needs a resistor or direct to 12V, I believe they all are different
Bob
Old Apr 13, 2024 | 08:37 PM
kts1962's Avatar
kts1962
Depends on which “Electronic Ignition”
if ‘Pertronix III’. The you need full 12v when Cranking the starter and when in ‘Run’. You will need to bypass the ballast resistor on the firewall (Pink Wire) and draw a second lead from starter circuit
then the red wire from Electronic Ignition in the distributor goes to Coil + along with the pink wires. And the Black wire to Coil -
but it will a important to go EXACTLY by the product’s instructions.
Old Apr 14, 2024 | 10:39 AM
prestige6's Avatar
prestige6
Got no instructions with it.
Old Apr 14, 2024 | 10:45 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
What brand or where did you buy it.
Old Apr 14, 2024 | 11:06 AM
63driver's Avatar
63driver
I went with the M&H unit for my 63. It uses one black wire. Looks like a stock setup. It's been in the car for about 20 years, no problems.
Old Apr 14, 2024 | 11:18 AM
65GGvert's Avatar
65GGvert
Google the instructions for whatever you are installing.
Old Apr 14, 2024 | 11:33 AM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Electronic
I had an electronic ignition fail on my C1 and it left me stranded. I switched back to good old points and condencer and cary a spare set in the car.
So if the points go belly up, a scew driver and feeler gauge is all I need to get home.
Old Apr 17, 2024 | 09:57 AM
Drummer Boy's Avatar
Drummer Boy
AMEN to that!
Same with me.
Points were good enough at LeMans in the 60's to win a race.
Eddie
To 63 electroic ign. install
