When performing a compression test, for how long do I crank the engine? For example, is there a fixed number of revolutions or do I just keep cranking until the pressure no longer increases?
I count to seven revolutions for each cylinder. To get a apples to apples comparison between each cylinder I felt it important to rotate each cylinder the same number of times. This logic may be totally flawed. I am not an expert on compression testing.
Just make certain to have a battery charger on hand when you do this, It is very easy to get involved and that battery runs down really fast. When you are finished with the test I recommend that you put the charger on for a bit to straighten it all out.
One time I did the test and after it was completed I started the car and drove off. Got to where I was going, shut it down and 20 minutes later returned to a dead battery.
Fair warning!
Eddie
Fair warning!
Eddie
Hmmmm..... That suggests that the charging system wasn't working during your drive.
Jim,
I thought of that but upon testing and monitoring, it seems as though all is in order. I see a steady 13.5 to 14.4 volts all during my drives, day or night. I suspect that the battery is not as substantial as I might think and further----I might have gotten a "Little aggressive" by over cranking during the test(s).
I was trouble shooting my rebuild(excessive oil consumption) and might have become too focused on things.
More on this in another post to come.
Jim,
Eddie
My vote would be a battery on its way out. Removing plugs and performing a compression test should have zero effect on a good battery's capacity.
Dan,
I agree with you but does it not also depend on how long and often one cranks the engine. Especially if the one doing the compression test is a novice at the test and tends to over crank also, just doing the test in many cases indicates a problem which means the tester is concerned about a potentially serious problem and in that frame of mind might do a lot more cranking than a more experienced person.
I only made that suggestion as a caveat. It cots nothing to have a charger on hand "just in case."
And yes, one time when I got burned by this it was dues to a bad battery.
Eddie
The charging system doesn't like when the battery gets run down, it's a good idea to charge it after extended cranking, before using the car. Then again, a tired battery will not be able to crank the engine as long as a fresh new battery will.
So you're both right
That's exactly what was trying to say in my usual "long winded way."
Thanks for simplifying.
Eddie
