Header Help Please
Old May 13, 2024 | 01:27 PM
Lindy65's Avatar
Lindy65
Default Header Help Please
Installing a 383 in the '63, double-checked and this engine has 1/2" raised port heads. Is anyone aware of an off the shelf header that will fit in this situation?
Concerned that going with a "normal" set will result in issues with the tubes/collectors hitting other parts of the engine and/or car. Also need to clear the clutch "Z" arm.
Prefer long tubes vs. block huggers/shorties.
Thank You!
Lindy
Old May 13, 2024 | 01:54 PM
Factoid's Avatar
Factoid
I used these Doug’s on my Blueprint 427 sbc with raised ports. Perfect fit with the z-bar, TKO600, and Borgeson power steering.
https://www.summitracing.com/parts/dou-d334-b
Old May 13, 2024 | 01:58 PM
Lindy65's Avatar
Lindy65
Thanks Factoid!
I had called Doug's tech. support prior to posting here, and they seemed pretty adamant that their 334 would cause interference issues with the 1/2" raised ports.
Bit confusing...
Old May 13, 2024 | 06:04 PM
Factoid's Avatar
Factoid
If you order from Summit, they have easy returns just in case they don’t fit. Doug’s may just say that as a standard statement from their lawyers!
These are the heads on my engine and the exhaust ports are raised.
https://blueprintengines.com/product...sembled-hp8103
Old May 16, 2024 | 07:53 AM
73bbc's Avatar
73bbc
Sanderson Headers makes headers for the raised port GM heads and D port heads. They may have what you need.
Old May 16, 2024 | 08:46 AM
Hashtater's Avatar
Hashtater
Default headers
Do you have sidepipes? I also have a 383 and used these headers from Summit. No power steering so easy installation. Awesome sound with original sidepipes.
Old May 16, 2024 | 01:02 PM
Jam421's Avatar
Jam421
I second Doug's Long Tube Headers as they're on my BP 383 with raised ports.
Old May 26, 2024 | 10:00 AM
Lindy65's Avatar
Lindy65
Thanks all - greatly appreciate the help!
Going with the Doug's, and will document the install once we dyno the engine (this coming week) and the M-21 comes back from being R&R'd.
Old May 26, 2024 | 12:53 PM
PinkVetteLady's Avatar
PinkVetteLady
I used Headman on my AFR 195 heads hooked up to 3" GNM pipes.
Old May 26, 2024 | 04:43 PM
Lindy65's Avatar
Lindy65
Planning on something similar to this kind of side exhaust: headers going into (small) mufflers, then through stock crossmember, into cross over and then out sides.
To Header Help Please
