More Help
Old May 21, 2024 | 07:06 AM
Z-11's Avatar
Z-11
Default More Help
I have reassembled the E-Brake as found upon take down. Looked at the assembly manuals I have and do not see what the 2 brackets are at the spring tensioner are for. I also assume that the triangular item is to tightens cable. What am I missing. A lot I'm sure. Thx Again, Dennis
Old May 21, 2024 | 07:52 AM
thoyer's Avatar
thoyer
Those two brackets are for the seat belt anchors.
Not familiar with the triangular item - what year chassis?
Old May 21, 2024 | 07:54 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
It appears that you have a 65 + chassis. IF you are referring to the center seat belt termination cables. They bolt through the floor on either side of the drive shaft tunnel...
Old May 21, 2024 | 08:40 AM
Z-11's Avatar
Z-11
Bingo!.... 1966 Chassis, I was thinking I had overlooked something. It does indeed have seat belts Thank you again
To More Help
