Compression numbers
Old May 23, 2024 | 11:31 PM
Whatscooking's Avatar
Whatscooking
Default Compression numbers
What kind of a reading should you see on a healthy 327?
Old May 24, 2024 | 01:47 AM
silver837's Avatar
silver837
It varies depending on the cam and pistons . Do you know what they are ?
Old May 24, 2024 | 06:19 AM
Whatscooking
Only thing I know is it has 150.
Old May 24, 2024 | 06:24 AM
Whatscooking
What should a stock 327 250 Hp have?
Old May 24, 2024 | 07:16 AM
phil2302's Avatar
phil2302
150 is good. The important thing is that that all 8 cylinders have a similar result. + or - 10% is acceptable.
Old May 24, 2024 | 10:52 AM
silver837's Avatar
silver837
The consistent numbers show that the valve train is working as designed, as well as the rings .
To Compression numbers
