[C2] 1967 Corvette Hardtop Date Code?
Old May 26, 2024 | 11:04 AM
James B's Avatar
James B
Default 1967 Corvette Hardtop Date Code?
Hey guys, I've done a couple of searches, but I'm still not for certain about what the date code is on this hard top. Can someone help me out?
@SamEYEam
Old May 26, 2024 | 11:22 AM
65hihp's Avatar
65hihp
Doesn't it have to be 6 63? does the roof have the cut out relief bottom front of each side, ala 1963? It isn't vinyl covered is it?
Old May 26, 2024 | 04:24 PM
62corvette's Avatar
62corvette
Not a 67 top originally. Off a late ‘63 or very early ‘64. Window is June ‘63.
Old May 26, 2024 | 08:36 PM
James B's Avatar
James B
Thanks for the feedback. Here is the bottom of the top. I'll have to look to see the differences between the 63 tops and the other tops. This one came with dad's car and was painted to match by the previous owner. It doesn't seem to fit well. I need to do more research.
Old May 27, 2024 | 08:44 AM
73bbc's Avatar
73bbc
If you want the build date for the top it should be stamped on the underside of the fiberglass. Unfortunately, you have to pull up the headliner to see it.
Pics below are from my ‘67. Mfgr date Nov. 66.
To 1967 Corvette Hardtop Date Code?
