Upgraded To Electronic Ignition Problems
It’s not HEI and there’s no separate amplifier unit. More like a Pertronix distributor I guess. I agree his description just doesn’t make much sense to most of us. Hot coil with no voltage to it. 8 volts at coil by simply connecting two wires from ballast resister together. Without it making any sense it’s difficult ( impossible) to offer any answers. I would like to know what the voltage is at the battery and the coil with the engine actually running but it sounds like it will no longer run. Maybe posting some photos of the firewall wiring will turn up something. I assume the car probably has an original wiring harness. Is there any evidence of it being cut, spliced, repaired, taped up, etc? Have you tried cleaning the bulkhead connectors? Do you have another multi-meter or can you borrow one to check your readings? Calling the manufacturer/seller might help but the 8 volts and hot, de-energized coil description isn’t going to give them any helpful info either.
Sounds like you have a wiring issue. Is your car a manual or auto? From your description the engine was running and then stalled. Do you have a wiring diagram? You need to ensure your ignition wiring is correct. At a minimum, find the source of the 8v and how the coil is powered when the key is off. It is possible you have a bad ignition switch.
Dan
Also, some electronic ignition manufacturers require a diode in the wire from the R terminal of the solenoid to prevent current flow to the solenoid when the engine is running. I don't know if your setup requires a diode or not.
In addition, what is the red wire on the coil + post? There also appears to be a connector with red, black, and tan wires under the distributor - is that the feed to the distributor? You have a yellow wire on the negative (-) terminal of the coil that goes into a wire harness - or - is behind the harness and a black wire out of that wire harness grounded to the valve cover bolt? Your problem may be in this added wiring harness for whatever it is. You need to find the manufacturer's wiring diagram for the distributor and if you need additional help, post it here for the experts to review. Also, the wiring diagram for the added red wire to the unknown device is needed.
I was trying not to express my opinion, but I have the stock points set up on R66 with over 13,000 miles and it is still running great. On the other hand, I have a Chrysler type amplifier with a magnetic reluctor type pickup on the 68RS and it starts easier and runs great also. Over the last 50 years or so, I have had Malory, Accel, and various other electronic components fail after a period of time. Neither is fool proof and lasts forever. Each individual is allowed to chose what he prefers.
Ron
Last edited by DansYellow66; May 31, 2024 at 09:19 AM. Reason: Brain fade - referenced wrong coil post
Do you have their contact info for tech? info@dragonfireperformance.com
They also have a phone number, but not sure if that will get you to tech....
888-732-7718
2304 Perseus CT.
Bakersfield CA 93308
2304 Perseus Court
Bakersfield, CA 93308
888-732-7718
23042304 Perseus Court
888-732-77182304 Perseus Court
888-732-7718 Perseus Court
888-732-7718
Ron
Thanks very much for the thoughts and suggestions. I will look again after work and take some more pictures if I have further questions.
Thanks again to everyone that is helping!
The most likely reason for measuring 8 Volts is that the switching transistor in the distributor is incapable of pulling the (-) terminal all the way to ground. Measure between the (+) terminal and ground for an accurate reading.
There most definitely should be continuity between the (+) terminal and the (-) terminal. Continuity is unrelated to whether there is applied Voltage or not.
This is not correct.
The law of diminishing returns is a textbook definition of what is realized when changing from a tried and true basic ignition system to something considerably more exotic.
I have always operated under the premise that I don't change OEM parts on my C1/C2s unless I understand how those components operate--that I need to know to fix them if something does go wrong. That is why I don't own any FI cars as daily driver despite Jim Lockwood's multiple tutorials on the subject.
I certainly understand WHY someone would want to do it----In my case, I simply wanted the latest technology and when it went wrong(first twenty minutes) I took it as a challenge and a "learning experience" to see if I could "solve the problem." It IS a hobby ya know. However, after a year of having my brother in law tow me home every time I went somewhere, I got tired os non starts, blown up coils and the like---and no one, including the mrf's of the parts could give me any further help it seemed prudent to cut bait----As the song says "ya gotta know when to fold em."
Yes, it was a learning experience-what did I learn---
First---"one size does not fit all"----these electronic units are not made for a specific car or electrical system but for a broad spread of cars----and each one is very different. There is just something about MY 62's electrics that simply does not like electronic ignition. So---who am I to argue.
2nd--the easiest solution is usually the right one---
Eddie
Eddie
For fun I hot wired the distributor (pink wire) directly to the battery. I did this to see if the ignition switch was an issue. it ran great in that configuration. so i went back thru the wiring and made sure everything was solid. I have not had an issue since.
Another thing to consider is the Voltage regulator, I read somewhere that not all electronic ignition modules have over-voltage protection, so if you are using the original voltage regulator (mechanical one) it could cause damage because it does not have over-voltage protection either. The old Vreg its a pretty crude instrument for maintaining voltage, but it works with an old points system because they are tolerant of spikes in the system. So, I removed the original vreg and got a solid state replacement (that looks like the original) to prevent that from happening.
Edit: so it is possible that the new ignition module (solid state) could be damaged now.
Easier and cheaper to manufacture.
