I am looking for the plate that is riveted to the firewall, on the inside, that the brake booster is mounted to and the steering column is located through. Its for a 67 convertible. I have looked on the usual vendor sites but cant find it. Anyone know where I can get one?
Thanks for the reply, however thats not the part I am after.
Obviously I described it incorrectly.
The plate I am after is located on the firewall, inside, the steering column goes through it a low level and the brake booster is located by it at a higher level.
It is contoured as it follows the different profiles of the firewall
