[C2] restomod engine removal
Old Jun 12, 2024 | 05:36 PM
rowingone's Avatar
rowingone
Default restomod engine removal
I am removing the LS3 from my 66 restomod with a Tremec 5sdp and Street Shop chassis. Better to remove engine and trans together? I don't need the trans out . . just want the smoothest removal. Any tips?
Old Jun 12, 2024 | 05:39 PM
rowingone's Avatar
rowingone
Also where do I attach the hoist chains? It has a magnuson supercharger on it . .when I pulled the engine on my 427 I just attached to the manifold bolts.
Old Jun 12, 2024 | 07:22 PM
DonBond's Avatar
DonBond
Manifold bolts still a good choice to accessory holes on front of heads. There is no right choice so use your imagination.
Old Jun 12, 2024 | 07:51 PM
vjjack04's Avatar
vjjack04
Accessory bolt holes in front and or back of each head.
Old Jun 12, 2024 | 08:50 PM
rowingone's Avatar
rowingone
I can access the front accessory bolt but not the rear . . is an exhaust manifold bolt ok? I don't want to remove the supercharger to use the intake bolt.
Old Jun 12, 2024 | 08:54 PM
Factoid's Avatar
Factoid
Are you changing the clutch while you’re in there? I would leave the tranny in the car but you will need to support it. If you change the clutch, it can sometimes be more difficult to then reinstall the engine with the new clutch given some misalignment even when using an alignment tool. It’s not impossible just more difficult.
Old Jun 12, 2024 | 08:57 PM
vjjack04's Avatar
vjjack04
Exhaust of intake should be ok.
Old Jun 16, 2024 | 09:03 AM
Skip Fix's Avatar
Skip Fix
Here is an LS cradle i saw . i have a few friends that love Mac's "pivot"
https://www.macscustomtiedowns.com/t...late/p/701001/
Old Jun 16, 2024 | 01:44 PM
mrichard's Avatar
mrichard
Exhaust manifold bolts on LS engines are too small to pull the engine with. I think you need maximum amount of bolt engagement in front and back of cylinder head accessory mounting spots. Those are 10mm (about 3/8"). Exhaust are only 8mm (about 5/16"). Assuming aluminum block and heads.
You might get away with using exhaust bolts, but I wouldn't. Remove the motor mounts and lower the engine on a jack, this should give you access to the rear head acc mounts.
Good luck. Michael
To restomod engine removal
