Radio Problems
Old Jun 23, 2024 | 08:37 PM
davcono's Avatar
davcono
Default Radio Problems
I have a 65 with a ZZ3 and MSD ignition module and distributor. My radio is a Retrosound Model 2. It plays fine while sitting, radio and USB, engine running or not. When I start to move, the sound cuts in and out. I have shaken all the wires looking for a loose connection to no avail. I installed a MSD capacitor thinking that might help, again to no avail. Any suggestions?
Old Jun 24, 2024 | 08:07 AM
thoyer's Avatar
thoyer
Check the connections at the antenna.
Old Jun 24, 2024 | 08:41 AM
B.Huey1's Avatar
B.Huey1
Be sure and check the grounds, front and rear when you check the connections
Old Jun 24, 2024 | 11:10 AM
65GGvert's Avatar
65GGvert
If the bluetooth cuts out too, I think you can eliminate the antenna. I have tried three Retrosound radio in three different cars. Two cut out at random when driving, and the other had so much engine interference that it was not usable. I added chokes and filters, no help. The only way I could listen was to mount the antenna all the way in the very rear of the trunk of a 68 Camaro and then I still could only listen to strong stations. That was not a bluetooth radio.
Old Jun 24, 2024 | 11:16 AM
Joemac8's Avatar
Joemac8
Exactly where are the front and rear grounds? (I have the same issue)
Old Jun 24, 2024 | 03:37 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
My guess along with grounds.
To Radio Problems
