[C1] WCFB float setting
Old Jun 25, 2024 | 10:53 AM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
Default WCFB float setting
I’ve been having issues with percolation on my 57 with dual wcfb carbs. Starts and cruises fine, but stumbles when hot and in slow traffic, especially in 90* temps we’ve been having. After shutdown, gas dribbles out of the accelerator pump nozzles on both carbs for a few minutes. I have read that lowering the float levels might help. My question is, by how much? 1/8”, 3/16” or what? Should this be done on both primary and secondary floats? I do have phenolic spacers under both carbs, and I have used both 10% and non-ethanol with same results. Thanks for any recommendations.
John
Old Jun 25, 2024 | 10:59 AM
thoyer's Avatar
thoyer
Do you have the intake crossover ports blocked? I never had issues with my 60 until I had the intake off and forgot to block the crossover when I put it back on. Percolation problem became quickly apparent. I lowered the float level about 1/8 which did improve some, but pulling the manifold and blocking the crossover did the trick.
Old Jun 25, 2024 | 11:10 AM
vettepoor's Avatar
vettepoor
Yes, I do have the block out plates installed.
Old Jun 25, 2024 | 11:28 AM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
You might want to look at using a phenolic spacer between the carb and the manifold.
Old Jun 25, 2024 | 12:40 PM
leif.anderson93's Avatar
leif.anderson93
If you re-read the OP's original post you will see that he already has the phenolic spacers installed.
Old Jun 25, 2024 | 03:10 PM
CBO's Avatar
CBO
VP let us know if when you resolve the challenge. I have dealt with this and feel I tried it all. Never giving up despite the Florida heat.
Old Jun 25, 2024 | 04:11 PM
Dan Hampton
How is the air flow through the shroud and radiator?
Old Jun 25, 2024 | 04:28 PM
vettepoor's Avatar
vettepoor
Air flow seems fine, Dan. No overheating problems, and car pulls strong. Plugs are burning nice and tan except when I have this percolation issue, then I need to drive it hard to clean up the gas fouling.
To WCFB float setting
