327 Engine Help
Thanks,
Jason
Thanks,
Jason
https://www.corvettecentral.com/c3-6...d%26count%3d18
This is the cover for the 70-74 divorced choke.
https://www.corvettecentral.com/c3-6...r%26count%3d27
I am also trying to decide if I want to use this Quadrajet intake and Holley carb on my 58 Corvette and the 66 327 engine I have going into it. I would appreciate people's feedback. I have 2 Holley carbs that I could put on this engine; Holley 6210 Quadrajet (650 CFM) and a Holley 3310C Classic Carb (750 CFM). I am leaning towards using the Holley 3310C and that would require a new intake manifold.
Anyone have any thoughts or what would you do? I would also love to have any recommendations for an intake manifold to use with the Holley 3310C Classic Carb.
I looked up the Holley 6210 Quadrajet car and Holley discontinued it, so my thinking is it may be better to go with a carb that is not discontinued.
I appreciate everyone's opinion and suggestions,.
Thanks,
Jason
The older 4 bbl intakes were for the early carters with the smaller throttle bores. If you use a modern 600 cfm Holley or Edelbrock AFB on them, you need a 1/2 inch spacer to make them work. Thus, your best match for the Holley is a post 65 GM intake or an aftermarket intake. However, they still used a Rochester with a different bore and spacing after 65. Just be sure to measure the throttle bore and bolt spacing of the carburetor you want to use and compare it to the specifications of the intake.
The hot gas passge under the carb was also intended to warm up the carb, not just operate the choke, quickly., But you have to consider that modern fuels are different. We have many more complaints here these days about fuel percolation from a too hot carb than we do about slow warm up. Given that you are in Texas, it's likely the benefits of blocking the exhaust crossover passage will outweigh any downsides. You can always adjust the choke, too.
Thanks,
Jason
There is a very important distinction between the exhaust crossover passage (which is important for proper operation of the divorced choke) and the "hot slot" that runs under the primary bowl of the carb.
The crossover path through the intake manifold is placed under the carburetor and works in conjunction with the heat riser valve attached to the passenger side exhaust manifold. The entry and exit ports for the crossover path are in the heads. This passage is intended to warm the carburetor on cold starts. The crossover passage was a feature of all carbureted Corvette engines. To operate the divorced choke, the crossover passage is very important.
The "hot slot" under the primary of the carb was a short-lived experiment that failed, according to John Hinckley (RIP). John said the hot slot was an attempt to provide additional heat to the carb for cold starts, beyond the heat provided by the traditional crossover passage. The hot slot caused numerous carburetor fires and was discontinued after just a few years. John recommended blocking the hot slot for all cars that had it. Blocking the hot slot has no effect on the operation of the traditional crossover path and the traditional divorced choke.
With today's gas that has a lower boiling point than gas from the 1960s, it is even more important to block the hot slot to prevent percolation when the hot engine is shut down, which can lead to vapor lock when re-starting the engine is attempted. Attached is a photo of how I blocked the hot slot on my '67:
Any racer will tell you the engine produces more power when the air and fuel charge are cool.
As far as Holley or Quadrajet, that is a personal preference and I don't offer an opinion. If you are just cruising on the street, either a stock cast iron or aftermarket duel plane intake will work just fine in most cases. Some aftermarket intakes are designed to perform at or above the normal range of an engine driven on the street - about 2,500 rpm. I don't recommend a single plane intake for street use, although I have used them for street / strip cars.
For the what it is worth - maybe $.02 which today is nothing.
Ron
The part that the OP circled in the post #1 photo is the thermostatic spring for a "divorced choke" that operates the choke. It is heated by a passage (not visible in the photo) on the underside of the intake that connects to two ports in the heads. Exhaust gasses flow through this passage from the passenger side to the driver side, deep under the carb, to warm the carb and help with cold weather operation. This system was used for many years and it works fine, but the choke plate on the carburetor requires some linkage to connect to the thermostatic spring. An alternate solution is to use a carb that has an electric choke.
The "hot-slot" that is visible in the post #1 photo is not the passage described above. The hot-slot was a short-lived GM experiment to provide additional carb warming in conjunction with the existing the passage that runs deep under the carb. Reportedly the hot-slot caused several carb fires and was discontinued.
The main point that I'm trying to get across is that the passage (not visible in the photo) that runs directly under the thermostatic spring and the carb works fine and helps the choke respond faster to warm up from a cold start. The hot-slot is a completely separate passage that turned out to be a bad idea. Blocking the hot slot has no effect on the main passage that runs under the thermostatic spring and the center of the carb. It is common practice these days to plug the hot slot.
If desired, I can take some photos that show the main exhaust crossover passage that is not visible in the post #1 photo.
One other question about my intake manifold. I am assuming the item that I have circled in the picture was used to pug items in to access the engine's vacuum. Does that sound correct? So if I don't have anything to plug into it, I could just plug that hole.
The vacuum fitting can be replaced with the correct sized threaded plug .
Are you trying to build a correct engine for your car ?
Is it the original engine ?
