charging issue 56
Make sure your light switch is OFF so you dont burn out your bulbs too.
It should read around 15+ volts.
If it does, likely the new VR is bad. I've had 2 brand new VR's fail once.
If not reading 15+v, still around 12.3, bad generator. Check to make sure brushes are released from their "lock" position and touching the armature copper contactors.
Also ensure the generator ground is a good connection, and the 1/4-28 bolt to ground it to the generator harness is not too long.
And verify your F + A generator harness wires are going to their proper terminals on the VR.
You can also "motor" the generator but you need to measure current draw for best process.
Release the drive belt. Disconnect harness to regulator. Connect Bat+ to A terminal via a Ammeter, ground to case. Then Ground F terminal and it should spin. Reading should be around 4 to 5 amps.
E. G. Here....
Rich
Disconnect the field wire from the regulator. With engine running at fast idle and your digital volt-ohm meter connected to the battery use a jumper wire to ground the field terminal of the generator to the generator case. If you get 15 + volts you have a functional generator and a problem regulator or the wiring between them.
Dan
Evidently I posted at the same time as the other fella, same advice.
Dan
But... is your regulator grounded?
Correction. Thats for 58-62. On a 56/57 its in the engine harness, a blk or blk/white tracer wire, i forget.
Regardless, verify VR is a solid ground, and ensure that ground is connected to the VR metal base with a screw and lockwasher, not the insulated rubber mount screws.
Rich(the other fella....lol)
Dan
