[C2] 63 grounds
Old Jul 28, 2024 | 06:01 PM
Whatscooking's Avatar
Whatscooking
Default 63 grounds
Where should they all be. One comes from the heater/ wiper to ground with the battery cable, is that all on that one? The antenna has a flat strap going to the frame. The dash ground heads to the radio plug that splits and grounds to a metal frame behind the clock, where does that frame get a ground? I see a ground wire comming out of the wiring loom left front to the raidiator, where is the ground go for the wiring harness?
Old Jul 28, 2024 | 06:59 PM
tbarb's Avatar
tbarb
All the ground you mention lead back to the negative battery through the bird cage and the frame.
To understand it better get an assembly manual and study the areas you are questioning, it's to much to type.
