[C1] '62 FI generator pulley alignment problem
Old Jul 29, 2024 | 01:37 PM
jerrybramlett's Avatar
jerrybramlett
Default '62 FI generator pulley alignment problem
My original 268 generator has solid end plates without rubber bushings with a 4" diameter, flush-mount deep V pulley. I also have an original 3768152 U-bracket with a reproduction 3755555 plate. However, my set-up is 1/4" off in alignment with the water pump pulley (see first attached photo). Has anyone else had this problem?
I've reviewed all the material I have here... a 1966 Chevrolet P&A Catalog, the most recent NCRS '61 - '62 Judging Guide, and a Corvette Central Catalog. They all say that '62 FI cars used a combination of a #3768152, 7.125"-long U-bracket and a #3755555 mounting plate or "brace" with a 268 generator. This combination of parts can't be mounted incorrectly; the bolt hole locations are symmetrical.
I'll probably end up modifying the repro plate somehow or install the earlier "wrong" pulley with an offset (last photo) to make it line up right. Thanks for listening.
Old Jul 29, 2024 | 03:07 PM
Vettrocious's Avatar
Vettrocious
2017 C2 of Year Finalist
Is there a spacer under your water pump pulley?
Old Jul 29, 2024 | 03:27 PM
jerrybramlett
Good point. Yes, the reinforcing plate is there. It does make the misalignment a little worse, but not by 1/4".
I'm now suspicious of my water pump pulley. It appears to be a reproduction since it isn't stamped 3724816 or GM.
Edit: False alarm. With my glasses on I can see the 3724816 GM stamping on the pulley.
Old Jul 29, 2024 | 04:36 PM
61corv's Avatar
61corv
If I remember I had the same issue and drilled about 1/4 inch and made bracket holes elongated the hole to line up. I even tried new brackets too.
Old Jul 29, 2024 | 04:39 PM
66BBCoupe's Avatar
66BBCoupe
2025 C3 ('68-'73) of the Year Winner - Unmodified
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
I had that issue with my 61 but that was caused by use of aftermarket headers - problem was solved for me by just having the plate modified at a machine shop to elongate the mounting holes for back and forth adjustment.
Old Jul 29, 2024 | 04:48 PM
jerrybramlett
Default Well, I never...
Turns out it was the new Stewart water pump I bought and installed back in 2005.
The pulley flange pressed on the pump shaft is positioned too far away from the pump casting. I can fix that, but the pump has to be off the engine to do it right.
Sorry I wasted anyone's time with this.
Old Jul 29, 2024 | 06:05 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Jerry,
I just measured from the FI adapter plate to the centerline of the belt and got 4.1". My point of reference on the adapter plate was a point directly in front of the more forward of the two thermostat housing bolts.
I realize this is too little, too late to be useful since you've already found the cause of the problem. Maybe it will help some future researcher, though.
Jim
Old Jul 29, 2024 | 06:07 PM
napa68's Avatar
napa68
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
I think we all have been there before Jerry. At least you found the problem an followed up with the root of it! I remember in my earlier parts store days when we had issues as such, more on the reman pumps.
Tim
Old Jul 30, 2024 | 12:28 PM
Leo Guggenbiller's Avatar
Leo Guggenbiller
Glad you located the problem. I learned from this post that one has to look at ALL the variables when issues arise. Personally I would have never thought about the water pump flange. Thank you!
Drive em safe
Leo
To '62 FI generator pulley alignment problem
