Replacement heater switch 63 Corvette
Old Aug 23, 2024 | 04:53 AM
BernardR's Avatar
BernardR
6th Gear
Default Replacement heater switch 63 Corvette
Hello, I recently ordered a temperature and fan controller to repair the defective controller in my 63 Corvette split window. The part is a vintage air controller but it has an extra part connected to it. I guess this is an additional part to control the rear fan with i do not have as it is a 63 Corvette. I am not sure if i have to use this or if i can simply remove it. I'm also not sure where to connect the brown cable from my current wiring harness, I suspect it is the 12 V power in. I think the yellow, light blue and orange cables are for controlling the speed of the fan. Maybe someone has experience with these switches? (see attach.)
