1966 Repaint
Yes - they are a good shop that does many restorations but not always on C2 corvettes.
I am having the whole thing stripped and redone but want to be certain it doesn't happen again in 10-15 years.
You can do a search in the paint and body forum section under General Subjects and find a lot of discussion on contamination and paint bubbling.
- The more layers of paint, the more opportunities for failure. Are you stripping the car to bare fiberglass?
- Common contamination areas include the hood and fender near the brake MC and area around the gas filler. Have these checked carefully for contamination.
- My ‘64 has three layers of paint/primer. It chipped and cracked around the windshield trim, around the hood opening recess, and in the front side vent areas. These are common locations for poor prep. Removing all trim, glass, doors, hood, etc help prevent these issues.
- Areas of body work require time to cure, outgas, and shrink. Allow proper time before top coating.
- The final wipe down and tack is one of the most critical for a smooth, blemish free finish. Does the shop have a dedicated down or side draft paint booth? Is it clean and well maintained?
1. Get references, and LOOK at the painters past work
2. Have your painter use ONLY brand name paint, ie: Dupont, Sikkens, PPG, Sherwin Williams. Most paint mfrs have a "shop line" (cheaper) paint, and a premium paint. Use the latter. Don't cheap out on primer/sealers
3. LOOK at the painters shop. If the shop is dirty, disorganized, etc. RUN away (there will always be excuses "all paint shops look like this", etc.
4. Under NO circumstances give him "work on it when you have time" bit, or you'll never get your car back (commonly called paint prison.
5. Get a contract. It doesn't have to be anything fancy, but should include a start date, type and brand of materials being used, a cost estimate for material and labor (shop expenses), how "add ons" are going to be calculated (usually cost per hour), how you are going to be kept in the loop, and most important, a drop dead completion date barring some unfortunate discovery while stripping, bodywork, etc. I would also add a "overage deduct" against the painter, if it is not finished as promised.
Which one is Most important??? ALL OF THEM. I've painted hundreds of cars. Not all Corvettes. As a painter, my reputation rides on the job that I do. I'd like to think that any customer that I have painted for, would come back to my shop for work (I have had some do that). I usually allow my self 60-90 days for non body off strip/paint/buff of a Corvette. That includes removing bumpers, trim, w/s, then stripping the car, minor body work (owner is notified immediately if some unknown problem pops up, primer, sealer, color/clear, cut and buff, and reassemble trim etc. Removing glass, doors, hood, etc is outside the normal scope, and adds about 15 days to my "drop dead" finish date. With all that being said, most jobs take less than 30 days, and I've never had one go past my "drop dead" date. I've done many, many cars. Some are full builds, and some are touch ups. Your painter is probably not going to want to hear this story, but I've been around this block many times, and what I say is truth. You don't have to do anything that I say, but you asked for an opinion. Trying to get information from guys that are not painters is worthless information. I hope this helps. I quit two years ago, so don't ask if I'll paint your car
BTW, I always did my own work. I never had a single $15/hr "trainee" working on a customer car. Ever. Maybe another question, if you're using a bigger shop.
