[C2] Engine manifold plug
Old Sep 6, 2024 | 02:07 PM
CorvetteMikeB's Avatar
CorvetteMikeB
Default Engine manifold plug
I want to change the location of my temperature sensor shown below to a water neck with a 1/2 inch needed sensor thread. My radiator hose lays directly on the black plastic connector with much weight on it.
What engine manifold plug do I plug do use? Any sealant needed? If you could give my a Summit Racing part # that would be great. My sensor is not working either, so another reason to do this.
ACDelco 12334869 - ACDelco Gold Engine Coolant Temperature Sensors
Old Sep 6, 2024 | 02:57 PM
Factoid's Avatar
Factoid
Here you go.
https://www.summitracing.com/parts/fle-fpe-npt-12
Use ptfe pipe thread sealant
Old Sep 6, 2024 | 03:00 PM
CorvetteMikeB
Originally Posted by Factoid
Here you go.
Thanks, is this a hex wrench top?
Old Sep 6, 2024 | 03:52 PM
ChrisBlair's Avatar
ChrisBlair
Head Style:
Internal allen
Old Sep 6, 2024 | 08:23 PM
anyChevy's Avatar
anyChevy
Had the same problem, but had no where else to put it.
Replaced thermostat housing with an L79 style,
Solved.
Old Sep 7, 2024 | 11:12 AM
CorvetteMikeB
Delete
Old Sep 7, 2024 | 11:55 AM
ChrisBlair's Avatar
ChrisBlair
I am biased against chrome things near coolant
Old Sep 7, 2024 | 11:59 AM
CorvetteMikeB
You can always paint it any color you want.
Old Sep 7, 2024 | 12:30 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
You can also get the plug at your local ACE store.
Old Sep 7, 2024 | 02:40 PM
CorvetteMikeB
Delete
To Engine manifold plug
