I’m thinking about purchasing the 65 Corvette and I’m trying to decode the trim tag. I have most of it figured out, but I’m uncertain of the stamping on the bottom of the tag. Has anyone seen this before any additional comments on the trim tag and decoding would be greatly appreciated, thanks everyone
Awesome thank you I have no idea. Is there anyway to tell what options the car was built with I was seeing something about a ECL code, but I don’t see anything on there. Thank you again.
ECL codes was not used on AO Smith bodied cars or standard black interior. you only have clues that can be added or removed over the years
All you can get is built Dec 2 at the AO Smith plant, convertible body # 1515 for the year, was built Silver with black vinyl interior and sold by dealer Dec 14, 1964. (14 appears to be a change to whatever they stamped first)
That is exactly what it is. Dealers were supposed to do this but lots of them didn't. I have also seen them on vin tags.
The delivery date was supposed to be stamped on the VIN tag (that is the purpose of the "DD" section on the VIN tag), but some dealerships apparently stamped it on the trim tag while other dealerships failed to stamp it at all.
This is correct. The reason that dealers stamped the date on the trim tag vs the VIN tag (where it was supposed to be stamped) is that the trim tag is soft aluminum and the VIN tag is hard stainless steel...much easier to stamp the trim tag. You'll see very few VIN tags or trim tags stamped with the delivery date.
Thanks,
Think I got it.
TRIM Plates for 1965 had "STYLE19 467" and for 1966-1967 TRIM Plates had STYLE 467". The "19" was omitted.
If there's one thing that I've learned, but continually forget that I learned, it is... you can't count on any logical events from year to year on Corvettes!
Here's my '67's trim tag:
Well 63-64 are all together unique and can be tricky. 65-67 are basically the same and easy once you remember what plant it came from
