[C2] Changing a Tail Light Bulb
Old Sep 30, 2024 | 05:01 PM
DUVETTE65's Avatar
DUVETTE65
6th Gear
Default Changing a Tail Light Bulb
Can someone tell me how to remove the tail light on my 1965 corvette? I need to replace the bulb so I took out the screws but it doesn't want to move. What am I doing wrong? Also, should I stay with period-correct bulbs or go with Halogen?
Old Sep 30, 2024 | 05:10 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you remove the two screws in the lenses and the plastic lenses should pop out. if not then the gasket is keeping it stuck to the housing, it take a standard 1157 bulb. you could swap out to LED bulbs then you would need to change the flasher for LED
Old Sep 30, 2024 | 05:32 PM
65hihp's Avatar
65hihp
Get your fingers on the bulb, push in and turn a quarter turn counter-clockwise.. The bulb will pop out.. EZ. Go back in with incandescent bulbs.. They work fine for our very limited use, fair weather weekend cruisers..
Old Sep 30, 2024 | 06:51 PM
ChrisBlair's Avatar
ChrisBlair
Don't over think this. 2x remove screws
Wiggle lens up down left right, circular, gently, it will start to come loose and then pop free
Old Sep 30, 2024 | 07:14 PM
65GGvert's Avatar
65GGvert
After you get the two screws out of the lens, a knitting needle or a screwdriver or pic with a curved end, you can reach into the hole and hook the plastic lens and pop it out.
Old Sep 30, 2024 | 08:22 PM
anyChevy's Avatar
anyChevy
2357 bulbs have the same tail light output and a higher brake light output, so a little brighter when you’re braking and indicating
Old Sep 30, 2024 | 08:38 PM
Avispa's Avatar
Avispa
They do, I used those for years. If you want to stay with incandescent bulbs, these are BRIGHT.
https://www.speedwaymotors.com/Halog...Cl9FvNVn10SQos
Old Sep 30, 2024 | 08:40 PM
Dave Tracy's Avatar
Dave Tracy
Also, the bulbs are "indexed" in that there is a right and wrong way to put in. You will notice the lugs on the side of the bulg are not at the same level. If you already knew that please disregard.
Old Oct 1, 2024 | 03:12 PM
tuxnharley's Avatar
tuxnharley
When removing the bulbs there are a couple of things I have encountered. If they have been in there a long time some corrosion can occur. I recommend spraying some WD40 or similar around the base of the bulb and into the socket and letting it sit for a day or so before attempting removal.
Always wear gloves and be careful when pushing and turning as described in the posts above. That old glass can get brittle and shatter when twisting and pushing.
Sometimes the glass will come loose from the base when trying to remove it. In that case you will need long needle nose pliers to grab the edge of the base to remove it.
If the bulb/base is really stuck/ corroded in there you may need to break/remove the glass anyway so as to be able to grip the base.
In any case I recommend cleaning the contacts in the socket before installing a new bulb. Use some WD40 or similar with a Q tip and a pencil eraser to clean the contacts.
Old Oct 1, 2024 | 03:36 PM
65GGvert's Avatar
65GGvert
One other tip that I've seen happen a couple of times when someone put a brighter bulb in the rear I've seen it actually melt the lens.
Old Oct 1, 2024 | 06:12 PM
Avispa's Avatar
Avispa
I kinda worried about that when I put in those 10w/50w bulbs. Didn't hurt the lenses at all. The glass envelope is much smaller than a 1157/2357 envelope so the hot surface is a bit farther away. Never had a problem with 2357s for that matter.
FWIW, I used #1250 bulbs (also 50 watt) for my back up lights. Didn't hurt the lenses.
Old Oct 1, 2024 | 07:20 PM
65GGvert's Avatar
65GGvert
it kind of depends on how long their on, brakes and backup lights not so much tail lights driving long distance might do it.
Old Oct 1, 2024 | 10:43 PM
3154tm's Avatar
3154tm
my lenses showed signs of melting even though they had the stock numbered bulbs. of course someone could have used hotter bulbs at some point in the past and then changed them back. out of caution, i space the new lenses out with two gaskets. can't tell it.
Old Oct 9, 2024 | 10:22 AM
65GGvert's Avatar
65GGvert
Any resolution to the problem?
To Changing a Tail Light Bulb
