Tach problem or distributor problem?
Old Oct 7, 2024 | 07:56 PM
1967's Avatar
1967
Default Tach problem or distributor problem?
When engine revs above 2500 rpm the needle does not drop down as the engine revs drop. The needle slowly goes down to about 2000 rpm and then drops back to idle. I replaced the cable and housing but it didn't help.
Old Oct 7, 2024 | 09:41 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Disconnect the cable from the distributor and chuck the core into a reversible drill. You should be able to test the cable and the free movement of the gauge with the drill. If that checks out, you can remove the brass bushing from the distributor body and pull the tach drive gear out. Be careful not to lose any shimming washers. These gears often get mangled which means more than likely the main shaft of the distributor has a chewed gear too. The only fix after that is to pull the distributor and rebuild it with a new shaft - or live with the wonky tach behavior.
Old Oct 8, 2024 | 11:31 AM
1967's Avatar
1967
Thanks for your help. How is the bushing held in or removed? Can it be done without removing the distributor?
Old Oct 8, 2024 | 11:51 AM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
How could the distributor possibly continue to "rev" after the engine rpm drops down? Think about this. Even if the gears were "blown" in the distributor how would they continue to "rev" faster than the distributor shaft as the engine slows down?
To Tach problem or distributor problem?
