Tachometer Issues
Old Oct 11, 2024 | 07:43 AM
cjviper16's Avatar
cjviper16
5th Gear
Default Tachometer Issues
Bought my 1966 convertible four weeks ago. When delivered the tach was bouncy when accelerating and then would settle down at speed. Tach just died last night. Is this a common problem and if so am I looking electrical hookups or is the tach itself probably dead?
Old Oct 11, 2024 | 08:21 AM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Tach
It's cable driven off the distributor. It's either the cable or the tachometer.
Old Oct 11, 2024 | 09:00 AM
cjviper16's Avatar
cjviper16
5th Gear
should have stated that it's got a ZZ4 350 replacement engine with an MSD ignition and distributor.
Old Oct 11, 2024 | 09:21 AM
DansYellow66's Avatar
DansYellow66
If it’s an MSD it’s definitely not common with C2s. I would check your tach wiring connections and grounding. MSD units are well known for complete MSD box failures. Don’t recall mention of just tach signal failures. That’s probably one of the simpler functions of the box.
Old Oct 11, 2024 | 11:36 AM
Duck916's Avatar
Duck916
There are MSD distributors with tach drives. So, first thing is to look at the distributor and see if it's got a tach drive cable coming off it.
To Tachometer Issues
