C2 Wiring Harness
Old Oct 16, 2024 | 02:10 PM
65 396's Avatar
65 396
Default C2 Wiring Harness
I replaced the under hood wiring harness on my 65. Everything works but the amp gauge. It completely pegs out and it ruined my gauge. I was told that the wiring harness did not include a ground wire from the voltage regulator to the horn relay. Can anyone tell me if this is correct or, if not, what my issue might be?
Thanks in advance,
Lee
Old Oct 16, 2024 | 02:24 PM
BD104X's Avatar
BD104X
I just replaced the harness in my '64, I used the retrofit harness from American Autowire and the instructions specifically say it does not support an ammeter - the choice was to either replace the ammeter with a volt meter or wire the ammeter yourself. I opted to go with the volt meter.
Old Oct 16, 2024 | 02:26 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Thanks in advance,
Lee
The ammeter works on a small amount of current. If 12 volts and ground were applied to the ammeter leads it will smoke. The ammeter has one wire attached to the horn relay and the other to the starter with small gauge wires that act as a shunt.
The issue appears from here as a miswired ammeter. The voltage regulator must be grounded to the chassis (battery negative) otherwise the alternator will not charge. However an ungrounded regulator will have nothing to do with the pegged and now likely smoked ammeter.
Dan
Old Oct 16, 2024 | 08:29 PM
Factoid's Avatar
Factoid
So their wiring harness shocked your ammeter to death, giving you the opportunity to convert it to a voltmeter. Nice.
Old Oct 17, 2024 | 04:34 AM
Argentimage's Avatar
Argentimage
Does Lectric Limited's harness do that? The big question is why would they do that where people are generally intending to go original...
Old Oct 17, 2024 | 05:33 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I did not have that issue when I replaced my forward (Light and Engine) harnesses on my 65 Coupe from Lectric Limited Products...That would have been around 2020..
Old Oct 17, 2024 | 07:38 AM
PWPOOP's Avatar
PWPOOP
FWIW.... I replaced all my 67 wiring with LL harness I bought last year & ammeter works as it should. And I am one of the electrical dummies on the forum. Thank goodness I labeled every connector when I took it apart 30 years ago.
Darin
To C2 Wiring Harness
