HELP! 1966 distributor problem
(driver's side). If I move it to the left side it won't even start. Plug wires are in correct order. Can the distributor be put back in off a notch or two?
Many Thanks,
COC
It's very possible that the place that pulled the distributor put it in a tooth (or two) off.
It really doesn't matter where the distributor is (with respect to the intake manifold - in terms of rotation) as long as the timing is right, and the wires are in the right order.
No more than two weeks ago I started a thread explaining in great detail how to properly install a distributor if you want your engine to perform properly, and it starts with proper removal. This thread also has input from Lars, and it was very received.
STOP POSTING MISINFORMATION!
The mechanics who worked on the OP's car are hacks and should not be in business working on old Chevrolets. Anyone who can change a light bulb should be able to correct improper distributor assembly and installation by following the step by step instructions.
Duke
Many Thanks,
COC
All right-left references to a car should be from the viewpoint of the driver sitting in the car. Therefore, the PASSENGER SIDE is RIGHT, not the driver's side, so you need to remove the distributor with the crankshaft properly indexed. Verify the orientation of the DIMPLE. Then proceed to install it properly and perform static timing. Then install the #1 wire in the correct cap terminal and the rest IAW the firing order.
Once you have a little experience static timing you don't even need a timing light to be confident that you got the proper value within a degree. Like Lars said, this is the way airplane engines are timed, because you don't want your head in the engine compartment live timing an engine with your body inches away from a spinning propeller.
Duke
https://www.corvetteforum.com/forums...sb-and-bb.html
I’ve read above article but Im still trying to get my head around why this is critical and what the negative effects may be ?
Im not an engineer obviously, so please don’t flame me, Im just trying to improve my tuning techniques
You can see in the above photo #1 is way off where it’s supposed to be, I’ve corrected that now and timed it again, but there was no noticeable difference in idle quality or WOT performance.
I’ve re read the article again, but it’s late, so I must me missing something ?
Thanks for your patience, hope you can enlighten me.
Cheers
Duke
When I recently pulled mine last weekend I simple read his-and Lars instructions---followed them explicitly---very clear and easy to do by the way----the car started up without even a short spin and ran like a top.
The instructions in PDF form are right here for the taking. This is no secret! If you cant download the PDF simply copy the text and paste it into a text document and print it.
There is absolutely no need to re-invent this particular wheel.
Thanks again Duke and Lars.
Best
Eddie
Ron
Thanks Leif, that is the one. You just proved my wife wrong, I can be right once in a while.I can't see how GM would recommend this if it affects the performance. The small block Chevy didn't change between the 50s and 70s.
It's not that it won't run if done like this, it's just not correct. When it's so easy to do things, like this, the correct way why not do so?? If everyone is singing off the same song sheet, it makes diagnosing problems sooooo much easier.
Cheers
There are 208 combinations of wire indexing, gear tooth engagement and dimple indexing - eight wire combinations times 13 gear tooth engagements times two dimple indexing choices. Not all of them yield satisfactory rotor alignment with the cap terminals at the firing point, and this can result in poor driveability such as was the case in this thread.
https://www.corvetteforum.com/forums...-resolved.html
Due to limited rotational freedom of the distributor and the need to have the tach drive reasonably aligned so as to excessively bend in the tach cable. there are a limited number of these 208 combinations that might work, and I'm not interested in testing all to find which ones might work, so I default to the way Chevrolet assembled and installed the distributor.
I figured it out 60 years ago ("the dimple issue"), and I've been helping guys correct screwed up distributor assembly and installations ever since.
I don't know the details of your installation, so I cannot comment on it. Maybe it works, but maybe it doesn't, and you just don't recognize the problems it might be causing.
I'm a mechanical engineer (BSME, MSME), been working on cars since I was a teenager, and my first job was as a production engineer at Pontiac in the late sixties, so I know my way around cars pretty well.
I've also been involved with some pretty sophisticated math - a fluid mechanics problem I had to solve in grad school that required me to develop and solve a system of partial differential equations.
About 20 years ago I ran across a textbook on Einstein's General Theory of Relativity at a library, and since it has always fascinated me, I checked it out to give it a read. Einstein's theory uses some very sophisticated math known as tensor notation that I had never previously been exposed to, and try as I might, I just couldn't get through it and had to give up.
Sometimes you just have to take things on faith, and in the case of Einstein's General Theory of Relatively I decided to take it on faith that gravity really does bend light waves without understanding all the details.
Duke
The 1968 service bulletin posted above, revises the plug wire indexing for better clearance on basically the same engine.
If it's just to get enough distributor adjustment between the intake runner and the shielding bracket ? Yes, I can understand that.
But I have to wonder what other possible problems there could be by indexing the plug wires one or two post around ?
Cheers
Dave
Duke
Understand that this applies to C3 Corvettes that have a completely different body, and the cowl is in a different position relative to the engine. It's my understanding that this was done to provide a more gentle bend for the tach cable, and it appears that this particular setup, one of the 208 possible combinations, did not result in rotor misalignment that could cause loss of spark energy that causes driveability problems like what occurred with the '65 L-78 in the thread I referenced.
Assuming you have a C2, perhaps you could try out this C3 setup and determine if is causes any issues with tach cable routing, VAC placement, and/or driveability issues. Let us know?
Duke
