[C2] '67 Trip Odometer
Old Dec 4, 2024 | 12:29 AM
sgorman3's Avatar
sgorman3
Default '67 Trip Odometer
The trip odometer on my '67 stopped working. Anyone know if this is a do-it-yourself repair? If so, what's a good source for replacement parts? If it isn't, any recommendations for a place that will repair it?
Old Dec 4, 2024 | 10:18 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
From many years back in my memory, I tweaked mine so it meshed with the other gear, and has worked as it should to this day. Obviously, I had the cluster/speedo apart. If you are not comfortable with that approach, contact Corvette Specialties Of Maryland West. Brian and techs are very good. There are others you can discover by using the "Sticky" list on the opening page. Dennis
Old Dec 4, 2024 | 11:03 AM
sgorman3's Avatar
sgorman3
Tnanks Dennis
Old Dec 4, 2024 | 11:48 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Make sure you pull down on the reset **** prior to disassembling anything. If it sticks upward then it doesn't mesh and operate correctly.
To '67 Trip Odometer
