Odometer Not Working
Old Dec 28, 2024 | 08:24 AM
cmr409's Avatar
cmr409
7th Gear
Default Odometer Not Working
I am evaluating a restored C2 corvette with number matching drive train. My only hesitation in pulling the trigger is that the odometer has not been working for a few years. Hagerty values the car at a price higher than the selling price. I would greatly appreciate any feedback from those with more experience than me.
Old Dec 28, 2024 | 08:33 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Chances are the miles driven have been low during the non operation of the speedo...Prepare yourself for a expensive repair of the unit. That is the only concern that I think you should be aware of. Oh! And have the car inspected by an expert! that will ease you mind!
Old Dec 28, 2024 | 08:40 AM
63driver's Avatar
63driver
https://csofmdwest.com/speedometers-...r-restoration/
Typical cost to restore your speedo is between $190 & $275. That assumes you are pulling the cluster, removing the speedo and reinstalling. Just your labor. Lots of You Tube to help you on that.
Old Dec 30, 2024 | 09:37 AM
cmr409's Avatar
cmr409
7th Gear
Default Odometer not working
Thanks to all who have provided feedback. I appreciate your input!
Old Dec 30, 2024 | 10:27 PM
66sixtaillights's Avatar
66sixtaillights
I got replacement odometer gears from Zip. I had a local speedo shop put them in and generally go through the speedo. seems like the gears were around $75. and the speedo repair was around $180.
Old Jan 25, 2025 | 09:35 AM
cmr409's Avatar
cmr409
7th Gear
A belated thank you!!
Old Jan 25, 2025 | 09:51 AM
joewill's Avatar
joewill
xxx
Old Jan 26, 2025 | 04:08 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Before you get the speedometer rebuilt, make sure the problem is the speedometer.
Disconnect the cable from the transmission, attach your drill to the cable spin it in reverse. Have your phone record a short video of the gauge to see it it works or not.
You might also have to see if the cable is spinning from the transmission. Remove the cable from the speedo. Snake the speedo end of the cable back out and into the engine compartment and with your wife or neighbor watching, drive up and down the driveway or around the block . If the cable spins the the driven gears in the transmission are good.
IF the cable is brand new my my money is that the cable is the cause of no indicated speed. The new cables sold by the big vendors are crap. For a few bucks more have a new cable made for your car that will work.
I strongly recommend:
John Rullo
2330 S. Kalamath St. Unit A
Denver CO 80223
United States
https://deluxespeedometer.com
Don
Old Jan 27, 2025 | 12:53 AM
L78's Avatar
L78
Originally Posted by vetsvette2002
…IF the cable is brand new my my money is that the cable is the cause of no indicated speed. The new cables sold by the big vendors are crap. For a few bucks more have a new cable made for your car that will work.
John Rullo
Denver CO 80223
United States
Don
I had that exact same problem, bought a new cable from a Corvette vendor and Speedo didn’t work (it had been working with and older cable that was tattered on the outside)…
ordered from Deluxe Speedometer, and very happy..
but also my odometer wasn’t working, tried to replace the gears myself and messed up the calibration…
sent it off to CSM-west, they rebuilt and recalibrated it…
my only complaint, it took 13 weeks…. I knew that going in…. Experts get busy.
Old Jan 27, 2025 | 02:47 PM
vetsvette2002
I had Joe Ray calibrate my speedo and tach, took only 2 1/2 weeks, including shipping times.
Don
Old Jan 27, 2025 | 02:50 PM
polo91's Avatar
polo91
I would be surprised if the odometer WAS WORKING!
To Odometer Not Working
