[C2] Headlight motor question
Old Dec 29, 2024 | 01:13 AM
66 C2 327/350's Avatar
66 C2 327/350
Default Headlight motor question
When I open or close my headlights, the right side head light is always much slower than the left. Does this mean I need to rebuild or replace it or is there some sort of adjustment? Thanks!
Old Dec 29, 2024 | 01:21 AM
66sixtaillights's Avatar
66sixtaillights
my left is slower than the right.....
Old Dec 29, 2024 | 02:59 AM
silver837's Avatar
silver837
You may only need to clean the gears and replace the grease. Don't use white lithium .
Old Dec 29, 2024 | 08:24 AM
R66's Avatar
R66
I believe it is normal as you have two motors drawing power from the same source and although they both may be new, one will get more power first and then the second. The wire to the right motor is longer than the left and there will be a bit more resistance in the longer wire. The connections to one may be a little better than the other. If you disconnect one, the one remaining connected will open faster.
I rebuilt both motors on R66 and the right one still opens slower than the left.
Old Dec 29, 2024 | 08:46 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
If I remember correctly there is a screw by the armature you can adjust for speed. Not sure if you can do it while installed
Old Dec 29, 2024 | 11:24 AM
PinkVetteLady's Avatar
PinkVetteLady
Also everyone focus on the motors. You need to remove the motors and make sure the pivot shafts are not rusted to the pivot ***** causing resistance.
To Headlight motor question
