What tool do I need to?
Old Dec 30, 2024 | 07:00 AM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
Default What tool do I need to?
What’s the name of the tool I need to buy to tighten this fastener on my ‘67 sunvisor?
Old Dec 30, 2024 | 07:10 AM
DansYellow66's Avatar
DansYellow66
A split tip screwdriver although the slots in your nuts look pretty worn. Some screwdriver bit sets may have a similar bit in them.
Old Dec 30, 2024 | 07:17 AM
66jack's Avatar
66jack
Or, Take an old flat blade screw driver and make your own...
Old Dec 30, 2024 | 07:20 AM
RatDog's Avatar
RatDog
Thanks Dan!
And, yes, my nuts are pretty worn <LOL>.
Take care,
Steve
Old Dec 30, 2024 | 08:26 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that is want dad and I did years ago. Works like a charm
Old Dec 30, 2024 | 08:54 AM
DansYellow66
Yes, if you have a dremel and some cutoff discs and an extra screwdriver you’re all set. But, if you are like many of us and have accumulated several screwdriver sets with a removable bit set, take a look through them first as there could be one in them.
Old Dec 30, 2024 | 09:06 AM
RatDog's Avatar
RatDog
Dan, I just went to my stash of bits and found a set. Unfortunately, the largest size is 8 which is too small.
I’ll just order a larger set from Amazon.
Take care,
Steve
Old Dec 30, 2024 | 10:19 AM
Corvette4me!'s Avatar
Corvette4me!
Not a tool you will use all the time, but just like the "clutch head" drivers used on C-1's, when you need them, nothing works as well as having one.
Old Dec 30, 2024 | 10:27 AM
73bbc's Avatar
73bbc
That's exactly what I did. You can get a screwdriver that is just the right width and blade thickness and the Dremel cutoff makes a perfect slot.
Old Dec 30, 2024 | 11:49 AM
Powershift's Avatar
Powershift
Steve:
I got mine from LICS years ago. ZIP bought LICS and still sells them. https://www.zip-corvette.com/59-67-s...river-tip.html
Larry
Old Dec 30, 2024 | 12:55 PM
Diablo427's Avatar
Diablo427
As has been said, you can make one fairly easily or, if you have some snap ring pliers, they work great. I use snap ring pliers for these type of nuts often. You have to hold them at the correct opening which is the only hard part. Headlight switch, sunvisors, almost anywhere that I run into these. Specific tool works best, but one can find ways when you don't want to wait.
To What tool do I need to?
