DOT 5 fluid availability
Old Jan 16, 2025 | 09:03 AM
vjjack04's Avatar
vjjack04
Default DOT 5 fluid availability
Any of you folks who use DOT 5 finding it harder to find lately? It seems that I cannot get the brands I used as readily as I once did. I had originally used Wilwood brand, but out of stock (for a while) at Summit and not in inventory at JEGS. I do see a brand on Amazon, "Quicksilver". Just wondering...
Old Jan 16, 2025 | 11:51 AM
Powershift's Avatar
Powershift
https://www.hirschauto.com/DOT-5-SILICONE-BRAKE-FLUID/productinfo/SBF/QUART/
http://www.clearcoproducts.com/pdf/specialty/NP-dot-5-brake-fluid.pdf
I like the Clearco product, but the 1 gallon minimum may be too much for you.......unless you share with some friends. However, the link I cut/pasted transfers over to Hirsch product website. So perhaps they are now the same. However, you can Google "Clearco DOT 5 brake fluid" and see the Clearco website.
The Hirsch Product is probably very good as well, although I have not bought it from them before. But the company has been around for decades supplying great automotive products.
Larry
EDIT: Some good info from previous discussions. https://www.corvetteforum.com/forums...e-fluid-2.html
Old Jan 16, 2025 | 05:09 PM
vjjack04's Avatar
vjjack04
Larry,
Thanks. I was hoping to find something at the local autoparts store. Hard to find here (Hereford AZ). Autozone, O'Reily, NAPA has none. Even Summit only has one type. I may look into the folks you mentioned.
Old Jan 16, 2025 | 06:00 PM
Aaron63's Avatar
Aaron63
If you prefer to shop local and you're open to other brands, another option might be calling the parts counter at a nearby motorcycle dealer. I believe some HD bikes used the DOT 5.
Old Jan 16, 2025 | 06:27 PM
pop23235's Avatar
pop23235
Larry
Response from Clearco today says they discontinued this product some time ago.
Old Jan 16, 2025 | 08:38 PM
Limp's Avatar
Limp
I just ;purchased a quart at O"reilly's recently.... Looked it up on line but when I went to the store the " younger fellow" could not find any and told me they must not have it...
Another employee asked what we were looking for and went in the back and came out with a quart..... Make sure you get someone knowledgeable at the store...
Old Jan 16, 2025 | 08:43 PM
Limp's Avatar
Limp
Harleys did use Dot 5 in their bikes for years... My research showed they stopped when they started using ABS braking systems..... Apparently Dot 5 does not work well in an ABS braking system.... At least that is what I read in my research..
Old Jan 16, 2025 | 10:59 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Not local unless one lives in Harvard IL... I bought my last quart from CTL Performance Products:
https://ctlproducts.com/products/car...iant=936490247
No issues at all.
Old Jan 17, 2025 | 04:40 AM
Argentimage's Avatar
Argentimage
huge caution for your amazon topic - most all is cheap china, make sure to deep dive who the seller is and where their product comes from, especially if ships from amazon,
Old Jan 17, 2025 | 08:30 AM
vjjack04's Avatar
vjjack04
Yes, that is true for most things. I live a little distance from a major metro area. We use Amazon for many things. Have gotten used looking for the right stuff from the right vendor. I didn't realize that I had used the "Quicksilver" brand DOT 5 before. It is a company out of WI (not sure were the product is formulated), One of the things though, like anything else the price of this is through the roof.
Link to the vendor, in case someone is interested:
https://www.quicksilver-products.com/en/
Old Jan 17, 2025 | 01:03 PM
Duck916's Avatar
Duck916
Rock Auto and Amazon both stock Johnsen's. It is allegedly made in the USA.
Old Jan 17, 2025 | 02:17 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
NAPA stocks DOT5. I seriously doubt it's in danger of going out of production.
Old Jan 17, 2025 | 03:41 PM
pop23235's Avatar
pop23235
Like other parts and qualified mechanics, these cars are phasing out of normal commerce. With the advent and widespread use of antilock braking, DOT 5 will eventually become difficult to find. Purchase volume will decrease, then production volume will follow.
Old Jan 18, 2025 | 07:57 PM
The Corvette Kid's Avatar
The Corvette Kid
I get mine from Advance Auto. It's Car Quest brand. Bob
Old Jan 18, 2025 | 11:11 PM
pop23235's Avatar
pop23235
O’Reilly carries it still.
Old Jan 19, 2025 | 09:09 AM
Limp's Avatar
Limp
As I said earlier its not on the shelves out front... My Qt. was in the back parts room....
Old Jan 19, 2025 | 10:08 AM
Skip Fix's Avatar
Skip Fix
Got some at Oreilly recently.
I think US military uses it besides motor cycles.
To DOT 5 fluid availability
Old Jan 19, 2025 | 10:59 AM
jim lockwood
In addition, according to a worker in my local NAPA it is also factory fill for some European vehicles.
My takeaway is that it's going to continue to be available for as long as any of us are around to care.
Old Jan 19, 2025 | 11:22 AM
Skip Fix's Avatar
Skip Fix
I did have one brand (forgot which) that the blue dye settled to the bottom of the MC in my 81 Trans Am. Called the company and they said it should not do that but it should not affect performance-not sure I believed them but still stops fine.
For those of you that have other project cars that use a rear disc kit with the Caddilac/79-81 Trans Am rear E brake ratchet calipers as many do, silicone fluid keeps the ratchets from locking up as was common with those PIA calipers. They are a 2.5" "metric" GM caliper with a built in ratchet for the E brake. Metric calipers can be swapped if you do not need an E brake.
Old Jan 19, 2025 | 01:56 PM
6D2148's Avatar
6D2148
FWIW, Do not confuse Dot 5 with Dot 5.1. Dot 5.1 is glycol base like dot 3 and 4. Three of my F650 Fords call for 5.1 and one of my guy’s was topping them off with dot 5 when servicing/ fluid levels. Two of them had calipers sticking at 70,000 miles, third one has been flushed, no issue yet.
Chip
