C2 splash shield
Old Feb 11, 2025 | 08:15 PM
D67's Avatar
D67
Default C2 splash shield
I have noticed from pictures of resto mods that the splash shields and dust shields have been eliminated. What are the advantages or disadvantages of doing so?
Old Feb 11, 2025 | 08:37 PM
KingRat's Avatar
KingRat
Do restomod chassis have provisions for the factory splash shields? Would it be an aesthetic choice? I'd assume they would not be needed.
Old Feb 12, 2025 | 04:39 AM
Argentimage's Avatar
Argentimage
These keep errant underbody air dirt water from coming up getting trapped in that area. Necessary? maybe - especially if you have modules and ebrake stuff in that area
tube chassis dont have mounting for these, the body does, unless you fill the holes - still can be added later before carpet.
I am not at that point to make a decision
Old Feb 12, 2025 | 06:16 AM
R66's Avatar
R66
Are they splash shields or for aerodynamics? I know of no other GM car that utilizes these closure panels and the C2 was designed to be a competitive car for the race circuit.
Wish John Z where still here to answer that one. Of course there are other knowledgeable members who may chime in.
Old Feb 12, 2025 | 10:18 AM
nutt's Avatar
nutt
Since the vette used chrome for the ignition shielding, it's possible the intent was to keep the engine looking purdy???
Old Feb 12, 2025 | 10:33 PM
Argentimage
you got the answer above
Old Feb 12, 2025 | 10:35 PM
Argentimage
Ignition shielding was there for a functional reason
Old Feb 12, 2025 | 10:40 PM
Dougs63's Avatar
Dougs63
2018 C4 of Year Finalist
2016 C4 of Year Finalist
2015 C4 of Year Finalist
What you gain by leaving them off is avoiding the pain in the *** from having to install them.
Old Feb 12, 2025 | 11:07 PM
nutt's Avatar
nutt
Cool.....noted.
Old Feb 13, 2025 | 12:14 AM
gleninsandiego's Avatar
gleninsandiego
I wonder about the cooling flow through the radiator
Right now mine are off
but would it help or hinder cooling flow leaving it like that?
Because I have an electric fan, I don't have a shroud covering the gap
behind the radiator bottom
I also have the restriction of an A/C condenser in front of the radiator
Thus I have the air entering the radiator's face with two exit points,
behind the radiator and where the splash shields are
What I wonder if having both of those spaces open would lessen the air flow
through the radiator by allowing it to bypass it,
or will leaving it open actually help?
Air flow can be counterintuitive and low pressure spots can develop that
cause the air to flow in the opposite direction you expect
I remember driving a convertible in the rain and the rain splattered the inside
of the windshield. LOL
Old Feb 13, 2025 | 08:16 AM
R66's Avatar
R66
My thought is the "splash shields" are actually helping trap heat in the engine bay. Minimizing the square feet of ventilation area for hot air to escape also reduces the cfm of air passing into the engine bay for cooling. Even with air, you can only put so much in without allowing so much out, like your tires.
I had a V-8 Vega and the engine compartment was so tight I had to open the hood a couple of inches to allow the air a path to flow thru or it would overheat with the biggest radiator I could stuff in it. With the hood gapped open, it would run under 200F.
Just my $.02
Old Feb 13, 2025 | 09:30 AM
Corvette4me!'s Avatar
Corvette4me!
If we're talking about the splash shields in the wheel houses, the C-1's have them too.
Old Feb 13, 2025 | 09:57 AM
Factoid's Avatar
Factoid
I left mine off. I don’t intend to drive it when it is raining or dusty.
Old Feb 13, 2025 | 09:58 AM
polo91's Avatar
polo91
Some protection to the firewall electrical components-------------maybe
trapping heat----------------------------------------------------------probably not, especially on 65-67
aerodynamics---------------------------------------------------------doubtful
useful------------------------------------------------------------------yes on a daily driver
pain in the ***--------------------------------------------------------definitely
Old Feb 14, 2025 | 06:12 PM
vettefred's Avatar
vettefred
Skip Shift
I have mine off also. Car runs a cool 165 deg. with twin fans and a DeWitt's radiator. 427 with cast iron exhaust manifolds. Cars interior never gets unbearable. I am not going to put them on to find out if it heats up.....LOL. Fred
Old Feb 14, 2025 | 06:50 PM
66jack's Avatar
66jack
Do/Did side pipe cars have them?
Old Feb 14, 2025 | 07:39 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Splash shields long gone. So are the ignition shields and spare tire. Don't need em... don't miss em.
To C2 splash shield
Old Feb 14, 2025 | 08:03 PM
Ol Blue's Avatar
Ol Blue
2024 C3 of the Year Finalist- Unmodified
Since these cars were made to be driven in all kinds of weather and roads, and yes even (shudder) gravel roads I would guess that they were there to keep water, snow slush, and rocks from "splashing" up on the body foot panel (unpleasant noise and feeling) and richocheting up into the engine compartment and possibly spark plugs.
Just a guess from someone that drove his new Corvette as indicated above.
Gary
Old Feb 14, 2025 | 09:01 PM
leif.anderson93's Avatar
leif.anderson93
Yes, they did.
Old Feb 14, 2025 | 10:52 PM
D67's Avatar
D67
I'm thinking they would restrict the air flow and trap the heat in the engine compartment. I am using a Dewitt duel fan rad with a GM LS3 hopefully I will not have a problem with overheating, but there could be heat transfer into to the cabin with the shields installed.
