Do you find, like me, that Philips screwdrivers cam out a lot, especially #s 0, 1 and 2. The screwdiver tip comes to a point, but so often the star hole on the screw-head doesn't. In fact the wretched hole is rounded at the bottom and the screwdriver can't go all the way in, so the wings don't engage properly. I'm thinking of grinding the pointy tips off my Philips screwdrivers to get around the problem. The bigger screwdrivers are O.K. because the tip is flat. What's your experience?
Do you find, like me, that Philips screwdrivers cam out a lot, especially #s 0, 1 and 2. The screwdriver tip comes to a point, but so often the star hole on the screw-head doesn't. In fact the wretched hole is rounded at the bottom and the screwdriver can't go all the way in, so the wings don't engage properly. I'm thinking of grinding the pointy tips off my Philips screwdrivers to get around the problem. The bigger screwdrivers are O.K. because the tip is flat. What's your experience?
Pozi drive will work, but a quality screwdriver is essential. Many less expensive Phillips screwdriver tips are pointed and will not fit properly.
I have used Snap On screwdrivers for years without issue. I also have a couple pozi drive in the mix but find that the SO ones usually work just fine.
Keep in mind as well, that the tips do wear out over time which will lead to them torquing out and buggering the screw head.
Many of the Phillip screws are made offshore and strip out easily. Same with the tools. I use Klein screwdrivers and the problem is less frequent. Jerry
Use a high quality machined tip (not forged tip) screwdriver for the screws that give you trouble. Milwaukee makes a nice set on Ebay with really nice tips.
Good Luck!
Thank-you for all the feedback. A couple of minutes with a file and all my Phillips screwdrivers are now Posidrive. However, I will order myself a set of the Milwaukee screwdrivers you recommend.
There are multiple cruciform screw drive types, and each of them are best driven using the correct driver. Phillips, Reed & Prince, Pozidriv, JIS B, Phillips 2, and others. Using the incorrect driver will sometimes get it done, but is more likely to cause cam-out and damage to the fastener and the tool.
I agree. It really is complicated and it doesn't need to be. In Canada, Robertson is pretty much universal and it's a great system. Not only does the screwdriver always fit properly and rarely cams out, if the screw head is clean, but you can fit the screw on the screwdriver and it stays there so you can install the screw with one hand This is great for installation in narrow or recessed places, and the other hand's free to hold a flashlight.
Sometimes, I use a wheeler screwdriver set used for gunsmithing that has various tips because those will bite better than any craftsman wrenches. I guess that is something to consider too is take all of the old craftsman and replace the ones thats are messed up.
I can tell you with two gearhead son's the worst part is getting ready to use a tool and not able to find it in the correct spot. For instance, I was ready to assemble my motor when I went to look for the torque wrench. Nope not there. My son had it in his car for some reason. Next thing, I went to look for my MAC tools thread chaser set. Nope not there, it was in the trunk of my son's car. Maybe some day the garage will be all mine once more. Maybe.... Talk about failure to launch. When are the kids supposed to leave?
