[C2] Body, Frame, Rear Bumper Alignment ???
Today I started to mockup the roof panel, rear deck panel, tail light panel, and the drivers side rear quarter panel. I have been using the grid layout from the assembly manual as reference. I have attached these for your reference. According to the grid layout the body line down the side of the car slowly slopes down from the front of the door to the rear of the car. From the front of the door to the rear of the door the line is about 5/8" lower in the rear. From the rear of the door to the rear of the quarter panel the line slopes down about another 1". My doors show the proper slope and after hanging the quarter panel on it also follows the proper slope.
In the next two pictures I have the green laser on and it is locked at the proper angle showing the alignment of the panels.
The next picture shows my problem and is what I am asking for input on. As you can see the tail light panel is sitting about 1-1/2" too high. It is above the frame and will make it impossible to install or use the bumper brackets in their stock configuration. When I bought the car it had this same issue. I thought that after disassembling the body that I would be able to fix this issue when I reassembled it. But everything has fallen into the same position.
When I bought and disassembled the car there were a ton of shims in the #4 body mounts. There was probably at least an inch of them. I removed most of them and have two thick shims in there now. This also helped level the rear floor section. But I have had to place a 3/4" shim between the rear deck and the rear bulkhead.
#4 body mount shims
3/4" block of wood between the rear bulkhead and rear deck.
I am not sure what to do here. Everything is driven by the doors which are sitting in the opening correctly. Level at the bottom with about 1/8" - 3/16" gap at the bottom of the door and the ledge of the fiberglass rocker cover (door jam). Changing any of the shims will not make a difference with the bumper brackets because of the body line.
*Removing #4 body shims only means that I have to add a thicker shim at the rear bulkhead to maintain the body line.
*Removing or changing the rear bulkhead shim changes the body line.
*Removing all the shims will really mess up the body line.
Should I just fabricate bumper brackets that fit this situation?
Has that been done before or is it common?
Any input will help, thanks.
If you think about it for a minute, body mounts 1 and 3 for a coupe are pivot points. Shims under #3 raises the rear and shims under #1 lowers the rear. The doors go with the body, so as long as you keep the shim ratios correct, the doors will stay aligned. I think you need to eliminate the shims at #4 and either remove shims at #3 or add shims to #1. I would try using shims to lower the rear while keeping the rest of the car aligned. If this doesn’t work, it is possible to bend that rear frame bumper mount up, but to might run into gas tank fitment and/or filler neck misalignment issues.
So yes, I did have the frame checked. When tearing into the car at the beginning I discovered that it had been crashed at least once, maybe more. There was a bent spindle at the driver's side front and the passenger side rear. I took the frame to a reputable corvette repair company. The gentlemen has been working on corvettes for I believe over 50 years now and he only works on C1s, C2s, and C3s. He has a frame jig that he placed it on. The rear of the frame was fine but he graffed on a new front section. I think that it would be hard to have a frame bent 1-1/2" and not notice it or have some type of crease that would be visible. Also the issue is uniform all the way across the back.
With that, there are zero shims at #1 because there isn't a front clip yet. #2 has an 1/8" shim and #3 has two 1/8" (1/4") shims. They are in there that way because I leveled the birdcage with the frame. The center of the frame (the section under the birdcage) is level with the lift. That way I have a uniform surface to measure from. If it is not important that the birdcage is totally parallel with the frame then I could make a huge movement at the rear by removing the shims at #3 and maybe adding one at #2.
I will look at that tomorrow, thanks
I am just not sure what to do. I do not want to start bonding panels until I am absolutely positive of the outcome. What I do here will affect the front later.
Would it be common for the body to be that far off from parallel of the frame?
Also, it sounds like you are keeping a consistently straight side character line through the doors and rear fenders. I may be incorrect in that. But I’m pretty sure that side character line/edge gently swoops down towards the end of the tail. Am I misunderstanding your post?
The firewall was removed and reinstalled with new body mount brackets using all the original rivet holes.
I re-read your first post again and i see you are allowing for the gradual fall off in the character line/peak from the doors toward the rear so I incorrectly remembered your description of that.
I am probably done for a while while I think about this. No matter what it appears that everything will have to come apart. Then either try to fix this frame again, locate another one - that will not be guaranteed, or call the Roadster shop.
I will have to convince the wife of the latter.
One curiosity though, if your #1 and #3 frame mounts seem to check out, then the issue of the birdcage rails not sitting relatively parallel to the frame rails remains unresolved.
