Need help diagnosing studder/noise
Old Mar 13, 2025 | 10:58 AM
corvetteed's Avatar
corvetteed
St. Jude Donor '14 thru '26
Default Need help diagnosing studder/noise
It's a '64 coupe w/original engine & transmission. Had this car 20 years, no problems. Started up normally. Ran okay for a mile then I noticed a kind of a backfire noise, but it wasn't a backfire. Chugged along for a second or two, then okay. Did this strange noise again, not a clicking, or shut off (like the dreaded red wire syndrome). Quickly turned around a came back home. All the plug and coil wires are snug. No corrosion anywhere that I can see. Red wire connection at the bulkhead is secure. Never heard this kind of a noise before, w/any car. Somehow, I feel it's an electrical issue, but I'm open to any and all suggestions. Many thanks.
Old Mar 13, 2025 | 11:19 AM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
If the pop and mild backfire you describe came from the rear of the car than its likely ignition related. If you have not removed the distributor cap in 20 years, and you have the original breaker points ignition, its likely the points are worn and/or the condenser is shot. Bad condensers present as you describe your symptoms. On the other hand your symptoms if accompanied by a pop under the hood instead of the exhaust could indicate fuel starvation from a plugged filter or tank sock. But this is far less likely.
It is far more likely you need to start under the distributor cap. Try a fresh set of correctly gapped points and condenser, set dwell and reset timing. Replace the rotor and cap if they are so old you cannot remember putting them on. One other thing, inspect the wire connecting to the points which moves with the breaker plate and eventually fatigues. I've seen cars running on just one or two strands!
Points replacements such as Pertronix or similar often fail the way you describe, so if you have one of those that would be the first thing I would replace.
Dan
Old Mar 13, 2025 | 11:35 AM
DansYellow66's Avatar
DansYellow66
In addition it could be the coil also acting up but just 1 mile down the road probably didn’t heat it too much. Usually they act after they are good and hot. But if points and condenser don’t fix it, the coil is worth swapping out.
Old Mar 13, 2025 | 12:48 PM
corvetteed's Avatar
corvetteed
Dan
Thx for the suggestions. The underside of the distributor cap and rotor all look brand new, same for points & condenser. Can't tell really if noise came from rear, but it seemed more like the front.
Old Mar 13, 2025 | 01:13 PM
thoyer's Avatar
thoyer
Keep in mind, just because the condenser "looks" new doesn't mean it is working as designed..........
Old Mar 13, 2025 | 01:22 PM
corvetteed's Avatar
corvetteed
Yup. I'm feeling more like this is the problem.
dplotkin's Avatar
dplotkin
Yes. You have to look at the rubbing block and the contacts on the points. Over time the rubbing block wears down the points close up and dwell changes. Eventually it'll start to run like crap. If the condenser is shorting or opening you will get backfires through the exhaust. If you can't remember when you last put a set of points in a condenser in this car I would do that now since it's about $20 in parts and an hour or less. Your symptoms sound like ignition.
On a distributor cap you want to look at the underside for carbon tracking. I think with a new set of points in a condenser you'll be good.
Dan
Old Mar 13, 2025 | 02:13 PM
65GGvert's Avatar
65GGvert
A loose or dirty connection on the black wire that runs from the -side of the coil up through the distributor and connects to the points plate under the dist cap can also cause those symptoms. I have had two that the black wire became loose at the coil and those things happened. Make sure that black wire isn't up against the ignition shielding where it could have a bare spot and touching intermittently.
Old Mar 13, 2025 | 03:48 PM
corvetteed's Avatar
corvetteed
Thx for the suggestions; I'll try to get to this tomorrow, but I may need to wait until next Wednesday. I'll let you know what I find out.
Old Mar 14, 2025 | 08:32 AM
corvetteed's Avatar
corvetteed
I double checked the black wire from the negative side of the coil up through the distributor and all was normal, no fraying. I don't have ignition shielding, so no problem with a bare spot there. Thanks for the suggestion. I'll keep everyone posted.
Old Mar 14, 2025 | 01:04 PM
65GGvert's Avatar
65GGvert
When I first got my 60 (same ignition setup), I had your symptoms intermittently. Every time I took the distributor cap off to check things it would run fine for weeks. Then it would start to buck and die again at random times. I decided to put in an SE Breakerless system and while I was installing I moved the black wire on the negative side of the coil and it pulled out of the connector. Checking the end of the black wire strands, they were corroded (sort of burnt looking). I cut a half inch off the wire and recrimped the connector that goes to the coil post and it has been several years now with no issue. Either end of the black wire can cause this, it's what provides the ground for the coil when the points close to create the spark. Pretty important for such a simple wire.
Old Mar 15, 2025 | 09:18 AM
dmtparker's Avatar
dmtparker
In my 62 I had a similar problem after hitting a huge pot hole. It was so bad, I thought I had broken something in the front end. Front end was fine, but then I started having the studder type problem you have. Long story short - the jolt had loosened the crimp on the red wire from the ballast resistor to the coil. Put on a new crimp - problem solved.
Old Mar 25, 2025 | 11:28 AM
corvetteed's Avatar
corvetteed
Update for anyone who cares: I told my mechanic about the noise and feeling of the ride (I don't do points/condenser anymore due to my arthritic hands) and told him of my suspicions of the points/condenser, and so he changed them, set the dwell and timing, and pulled the plugs to see how they looked {looked okay, but had a small amount of carbon build up, which he cleaned off}. He didn't take it out for a test ride. When the car was pulled out into the parking lot, right away I could hear a deeper rumble, sort of like a Harley Davidson motorcycle has, and a noise like it was about to stall out. However, I didn't say anything, as I wanted to take it home and see how it sounded and ran. It ran fine and never did stall, but I'm not satisfied that whatever was needing attention before still does. His only other suggestion was to replace the Holley carburetor. I'm not interested in making that change. My "plan" is to drive it some more and see what develops. I guess I'll also adjust the mixture a little on the carb to see if that improves it at all. His other suggestion was to really jump on it to get the carb & plugs cleaned. I don't normally drive that way, but I'll try that too.
Old Mar 25, 2025 | 12:06 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Arrrgh: the mantra of today's mechanic. No rebuild, no tune and test, just replace. I'm wondering just how much your mechanic knows and understands carburetors.
"About to stall out" sounds like it may not be idling high enough. Before messing with mixture screws, make sure that's at the appropriate setting, especially since your plugs looked OK. (I'd not change mixture without a vacuum gauge.)
Why did you say "whatever was needing attention before still does"? Wasn't the issue a cough or sputter when driving which it doesn't appear to have any longer?
Old Mar 25, 2025 | 01:17 PM
thoyer's Avatar
thoyer
How can you not test drive a car after working on it to see if the customers concerns have been addressed?
Maybe look for another shop - did a quick google search for Corvette shops in Wilmington NC (location in your profile) and found Rackleys, they seem to show several Corvettes on their web page. I have no knowledge of their ability so do your own due diligence before committing. Hopefully they weren't the shop you used...........
http://rackleysperformanceandauto.co...mance-gallery/
Old Mar 25, 2025 | 02:37 PM
corvetteed's Avatar
corvetteed
Thank you for the referral. That shop is about 45 minutes from me, whereas the one I used is only 10 minutes; plus I've used this guy before on a couple of my other old vehicles and he knows these older cars. He is in his 70's, and grew up w/them. I hope he stays working. There are some other recommended shops located closer to me than that 45 minute one, so if I'm not satisfied w/the current guy, I have a back up to go to. Thanks again
Old Mar 25, 2025 | 03:31 PM
corvetteed's Avatar
corvetteed
Yes, the sputter is gone, but what I was thinking was that the new rumble sound and the almost stalling behavior, could now be covering up the original issue, whatever it was. So, until I get a chance to put some time/miles on it, and see what is happening now, I'll remain skeptical that all is well. It's got to earn back my "trust"
To Need help diagnosing studder/noise
Old Mar 25, 2025 | 03:39 PM
leif.anderson93's Avatar
leif.anderson93
If you feel comfortable enough that the car won't leave you stranded by the side of the road, get it out on the highway and run it for at least 30 miles at 65-70MPH. It's what we used to call a "Poor Man's" tune-up. Putt-putting these old cars around is not in their best interest...they need to be blown out every once and awhile. You're not going to hurt it.
Old Mar 25, 2025 | 04:57 PM
DansYellow66
He may have set initial timing per the old manuals which are generally pretty conservative (retarded). I would check the timing and see if you can boost it several degrees without getting combined initial and centrifugal timing over 36 degrees which is typically a pretty good number for most engines. Low timing could make the engine feel weak-kneed at low rpm.
Old Mar 26, 2025 | 10:15 AM
corvetteed's Avatar
corvetteed
Another status update: I adjusted the idle, it had always been 7500 rpm, but he'd set it at 5000, which gave the almost stalling sound. Now that the idle is back to what I'm used to at 7500, it sounds 'normal' and doesn't feel like I need to feather it to keep it running at idle. Also, I took it out for a 40 minute 'hard' drive hoping to blow out the carbon, if needed. It seems to be running normally now, so I'm thinking that maybe it was the points & condenser all along. If there are any changes related to the original issue, I'll let everyone know.
Thanks for all the suggestions. I appreciate them.
