[C2] '66 Front Caliper Question
Old Mar 13, 2025 | 12:48 PM
Reeseb's Avatar
Reeseb
Default '66 Front Caliper Question
Does the wider brake pad go on the inboard side or the outboard side.
Thanks in advance for the help!
Old Mar 13, 2025 | 12:57 PM
Vet65te's Avatar
Vet65te
That's a new one on me, I've never seen anything but totally symmetrical brake pads all around. Any chance you have pads from different manufacturers?
Mike T - Prescott AZ
Old Mar 13, 2025 | 01:11 PM
thoyer's Avatar
thoyer
Pads should be the same inboard or outboard.
Old Mar 13, 2025 | 01:19 PM
bauto's Avatar
bauto
looks like 2 different brands of brake pads to me
Bob
Old Mar 13, 2025 | 01:23 PM
leif.anderson93's Avatar
leif.anderson93
Agree with others. Pads are symmetrical all the way around.
Old Mar 13, 2025 | 03:52 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Brake Pads
I wonder if that is some kind of hybrid pad set where the inner and outer pads are of different compounds ???
Ceramic/Organic---Organic/Metallic---Ceramic/Metallic. Raybestos makes pad sets like that where the inner and outer pads have different compounds.
RON
Old Mar 13, 2025 | 06:50 PM
Reeseb's Avatar
Reeseb
Thanks, everyone. I purchased the car from someone who redid the brakes about 4 years ago and sadly died shortly after. I had the calipers rebuilt and the pads were so nice, I figured I'd keep them.
Old Mar 13, 2025 | 07:04 PM
Powershift's Avatar
Powershift
Use new DELCO pads as shown by Leif above..........
Larry
Old Mar 13, 2025 | 07:37 PM
Reeseb's Avatar
Reeseb
Larry
Thanks.
Do those pads work for front and back? And it appears that you can change pads without removing the calipers. Is that correct?
Old Mar 13, 2025 | 07:44 PM
thoyer's Avatar
thoyer
Originally Posted by Reeseb
Thanks.
Yes and yes. You'll probably need to push the pistons back in to get the new pads in. Do one pad at a time
Old Mar 13, 2025 | 08:44 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Go on You Tube and search for "replace disc pads on a C-2 Vette. Also, get yourself a shop manual. Dennis
Old Mar 13, 2025 | 11:01 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Unless you want to put in new pads, I'd see if i could assemble matching pairs from the existing pads on the car. That the calipers would have different thicknesses doesn't matter and, really, neither does it matter on the same caliper, but my OCD would force me to pair them up! The Corvette calipers, unlike modern floating calipers, squeeze the pads on both sides of the rotor so are not dependent on the thickness of the opposing pad for effectiveness or safety.
If pushing the pistons back inside the calipers and if the reservoir is full, remove about 1/2 to 3/4 of the fluid to allow room for the line fluid to be pushed back into the reservoir. Keep the master cylinder cap bails loose but do not remove the lid entirely. The fluid forced back into the reservoir can spurt like a fountain and ruin paint.
Old Mar 13, 2025 | 11:45 PM
Avispa's Avatar
Avispa
Bob
it sure does, and Brand Left is missing a lot of friction material. The car will pull hard to the opposite side under braking if you use those pads
To '66 Front Caliper Question
