[C1] 1961 spark plug torque
Old Apr 20, 2025 | 06:16 PM
61 Maroon's Avatar
61 Maroon
Default 1961 spark plug torque
Hi all
is there a torque spec for spark plugs for the 283?I can’t find anything in the ST 12 that talks about thatThanksJohn.
Old Apr 20, 2025 | 06:28 PM
61 Maroon's Avatar
61 Maroon
Found it somewhere else
20-25 ft lbs
Old Apr 20, 2025 | 07:18 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
snug- plus. A little dab of antisieze helps also
Old Apr 20, 2025 | 07:45 PM
61 Maroon's Avatar
61 Maroon
Thank you
what do I buy for anti seize?
Old Apr 20, 2025 | 08:00 PM
leif.anderson93's Avatar
leif.anderson93
Originally Posted by 61 Maroon
Thank you
Big fan of Permatex copper anti-seize.
Permatex<span class=
Old Apr 20, 2025 | 08:22 PM
61 Maroon's Avatar
61 Maroon
Excellent
thank you
Old Apr 20, 2025 | 08:54 PM
R66's Avatar
R66
Be careful to not get it on the porcelain, only the threads. It will conduct electricity and you could see fireworks if it is in the boot or on the plug. You probably already know this, but thought I would check.
Old Apr 20, 2025 | 08:56 PM
jforb's Avatar
jforb
Anti seize is great for plugs that go into aluminum heads, but not necessary for spark plugs going into cast iron heads....remember iron heads?
Old Apr 20, 2025 | 10:12 PM
61 Maroon's Avatar
61 Maroon
Thank you all
Old Apr 22, 2025 | 06:49 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
Correct, especially if you use plugs with the copper gasket.
Old Apr 22, 2025 | 07:56 PM
61 Maroon's Avatar
61 Maroon
Thank you
Old Apr 24, 2025 | 06:53 PM
Drummer Boy's Avatar
Drummer Boy
20-25 ft lbs
My sources say 10 ft lbs for my '62
Eddie
Old Apr 24, 2025 | 07:29 PM
61 Maroon's Avatar
61 Maroon
Thank you
Old Apr 25, 2025 | 03:52 PM
73bbc's Avatar
73bbc
Older cars with gasketed plugs (not the type with tapered seats that don’t have gaskets) require 15 to 20 lb ft AFTER they have been tightened through gasket compression. The metal gasket is designed to compress on first use and you will observe one turn or so where the torque is constant as the gasket compresses, then torque increases as you continue to turn the wrench, allowing torque to increase to the proper level.
Lots of people used to stop turning as the plug got into the compression range but would stop before it was fully compressed, causing problems later when the plug would eventually back out.
Old Apr 25, 2025 | 04:06 PM
73bbc's Avatar
73bbc
Sorry. Rechecked my ‘61 service manual and the spec is 25lb Ft, not 15-20.
Old Apr 25, 2025 | 09:59 PM
61 Maroon's Avatar
61 Maroon
Thank you
Old Apr 25, 2025 | 10:13 PM
Pop Chevy's Avatar
Pop Chevy
I bet you are sorry you asked , now !
To 1961 spark plug torque
Old Apr 25, 2025 | 10:58 PM
61 Maroon's Avatar
61 Maroon
Ha!
Old Apr 26, 2025 | 08:56 AM
Drummer Boy
Eddie
I should have been more specific, sorry.
I have Edelbrock E street Aluminum heads installed on my 327.
Edelbrock info states that they require an "extended tip GASKET plug" and the torque set at 10 lb/ft"
This I have done along with a dab of anti sieze and I have never had a leak and further when I remove the plugs they are quite tight at the 10 lb setting.
Cast iron heads will certainly vary.
Sorry for the incomplete.
Best
Eddie
Old Apr 26, 2025 | 10:55 AM
polo91's Avatar
polo91
A little dialectic grease in the boot can be helpful on future removal and waterproofing. I use in on practically all electrical connections.
