front end bumping
Old Apr 30, 2025 | 08:12 PM
Scooter NYY's Avatar
Scooter NYY
Default front end bumping
I have a 1964 C2 convertible with the 327/365 engine. L76. No power steering, no power (drum) brakes, no A/C, basically the base 1964 convertible with the 365 hp engine as the only option. It is the 4 speed manual. I have only had this car for about 6 weeks and I really enjoy it.
When I drive the car and shift through the gears, 1st gear is fine, 2nd gear is fine, but when I get to 3rd and 4th gears between 3000 and 3500 rpm, the front end bumps like the tires are out of balance. I just replaced all four tires which were very old. I assumed that the old tires were out of balance or had flat spots but this is happening with the new tires. The clutch and transmission seem OK. The shop that mounted and balanced the tires is a excellent Corvette repair shop. I asked the owner what he thought about the transmission and he said it seems fine. I want to get this fixed but I want some ideas what may be causing this before I go back to the Corvette shop.
Any ideas what may be causing this?
Old Apr 30, 2025 | 09:05 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
What speed are you registering in the 3-4th gear range? Are you feeling this bumping through the steering wheel, the seats, or is the front body shaking? I'm guessing you have a suspension problem. What do you know about the shocks? Dennis
Old Apr 30, 2025 | 09:37 PM
Scooter NYY
The speed is around 50-55 mph and it seems to be just the front end shaking. I know nothing about the shocks and suspension system.
Old May 1, 2025 | 07:40 AM
DansYellow66's Avatar
DansYellow66
If the shocks look really old they may be shot. Back in the late 60s I bought a used car that the tires dribbled or bounced at higher speed. I didn’t know the cause at the time but put a new set of shocks on it and it went away. Also, did the tire shop check the alignment?
Old May 1, 2025 | 07:41 AM
SJW's Avatar
SJW
What happens if you shift into neutral and let the engine drop to idle speed while the vehicle coasts at speeds above 55 MPH?
Live well,
SJW
Old May 1, 2025 | 07:55 AM
Whatscooking's Avatar
Whatscooking
Jack it up and place something close to the tire and spin it checking for out of round.
Old May 1, 2025 | 08:23 AM
Tampa Jerry's Avatar
Tampa Jerry
Try swapping the front wheels to the back and the back to the front. Jerry
Old May 1, 2025 | 12:41 PM
scowser's Avatar
scowser
I agree with Tampa Jerry
Old May 1, 2025 | 07:25 PM
Scooter NYY
I drove the C2 today and got it up to 50-55 mph and 3000-3500 rpm and took it out of gear and the bumping was still there.
As for the tires, the old set of tires did this same thing as the new tires are doing so I tend to feel that the issue is not in the tires but as Bluestripe67, DansYellow 66, and SJW said, it sounds like an issue with the shocks and suspension.
Would you recommend a newer shock such as a Bilstein or go with replacement replicas like came with the C2 originally?
Thank you all for your help.
Old May 1, 2025 | 09:29 PM
SJW's Avatar
SJW
I would check all steering and suspension components for wear and damage. Although you reported that there was no change when new tires were installed, it would be wise to check for runout at the wheels & tires. As Dan noted, new shocks might solve the problem - is there evidence of leakage of the existing shocks? Is a steering damper present on the car?
Live well,
SJW
Old May 1, 2025 | 10:12 PM
scowser's Avatar
scowser
You've obviously got something that's wiggling. You don't really notice it when it's below its resonance frequency. But when you get to 50 m.p.h. it resonates and self-amplifies, so that's when you notice it. It's the same principle as the Tacoma bridge collapse in 1940. Shocks are there as a damper to stop the suspension from bouncing up and down, not to correct something that's loose or out of balance and wiggles. If you know for sure that your tires are balanced and not out of round and the wheels are straight, you need to check that there's no play in the suspension or steering. I'd start with the wheel bearings and tie-rod ends. If I had to place a bet, it would be tie-rod ends.
Old May 2, 2025 | 07:40 AM
DansYellow66
There are 2 different types of Bilstein shocks available and I believe the HD series would be what you want as the Sport series is pretty stiff. But any quality gas shock would probably work fine. What about the alignment question - has it been checked? It could be a combination of things coming together like near zero caster, weak shocks, some looseness in ball joints or tie rods, etc.
Old May 2, 2025 | 08:04 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
I would have a professional go through your front end/suspension checking every ball joint, shock, tie rod end, idler arm, wheel bearing, sway bar link and bushing, steering box, control arm bushing, etc., for wear, excessive play, and tightness. I had a ball joint come apart on a car (not a Corvette) about 40 years ago and was lucky it didn't do so at speed. Did the old tires show any cupping or other odd wear patterns?
Old May 2, 2025 | 08:25 AM
BD104X's Avatar
BD104X
I'm still trying to figure out what the OP means by "bumping"... is it a vibration you can feel? a thumping or other noise that you hear?
Old May 2, 2025 | 09:04 AM
Easy Rhino's Avatar
Easy Rhino
Yep, that's why I replied with the "check it all" answer. Guessing what's meant can lead to incorrect first conclusions.
Old May 2, 2025 | 12:34 PM
Scooter NYY
I'm going to have a garage thoroughly check out the front suspension, etc. They do a lot of work on older Corvettes.
What I meant when I said there is "bumping" at certain speeds is what you feel when you drive over real small speed bumps and it is noticable in the front only and seems to be more pronounced on the front driver's side.
Old May 2, 2025 | 12:44 PM
Factoid's Avatar
Factoid
I’m guessing either wheel bearings, tie rod ends, or control arm bushings. It’s only a guess because without proper diagnostic work we are all guessing and these are the other things that can cause vibration in the front end. OP, please post the results of what the shop finds.
To front end bumping
Old May 4, 2025 | 07:18 AM
CaptainEgg's Avatar
CaptainEgg
Almost Retired
Makee sure there are weights on the brake drums, they can be out of balance just like a tire if weight is missing!
Old May 4, 2025 | 08:34 PM
Scooter NYY
I'm having a Corvette mechanic go over the entire shock/suspension system on Monday, May 12. I'll let you know what they find.
Thanks to all for your help!
Old May 6, 2025 | 12:11 AM
TCracingCA's Avatar
TCracingCA
Too much could be wrong, just to add to the list of things mentioned to look at, also check the attachment of the lower a-arms as welding there could be an issue! I assume the rims were checked, when the tires were changed! Does the car wander?
