[C2] Holley replacement
Lately it has been running terribly.
Can anyone tell me the model number for a plug and play edelbrock that has the correct linkage connection for the Powerglide?
Thanks,
Captain Bud
https://www.edelbrock.com/performer-...-egr-1405.html
https://www.edelbrock.com/performer-...-egr-1406.html
They are very common, and I have a couple on the shelf.
If I recall, the PG rod attaches to the hole below the throttle plates on the throttle lever. A picture of what you have now would be helpful. Here are a couple to compare with:
I believe the Carter AFB also had the same throttle lever.
The only caution is fuel in the Eldebrock seems to evaporate quicker than in the Holley and thus if you park it hot, it can be hard to start after it sets for a while even with the electric choke.
Your fuel line will probably need a 90 degree fitting pointing down to attach the line and clear the air filter base. Of course, replumbing the PCV and power brake lines will also be needed.
I agree, the properly tuned Holley 3367 is preferable as you retain the divorced choke and fuel line, but that may have already been modified on your Holley.
There are three flavors of Holley 3367: original '66, service replacements, and then re-released 3367s in the early-2000s. I'd be on the lookout for the re-released 3367. Service and re-released carbs have 4-digit date codes. I believe this is one of the re-released flavors.
https://www.ebay.com/itm/335941923198?_skw=Holley+3884505
