[C2] shutoff
Old May 28, 2025 | 07:09 PM
Guinness1's Avatar
Guinness1
Default shutoff
do i need two shutoff valves to keep heat out of cockpit or just one fro top of block
Old May 28, 2025 | 07:15 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
One on the heater hose firing on the water pump works just fine
Old May 28, 2025 | 07:18 PM
Guinness1's Avatar
Guinness1
Old May 28, 2025 | 08:21 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
You will need more than a cutoff valve. Is your insulation on the interior firewall in place and in good condition? Are all the openings for cables and wires well sealed? If you have stock under body exhaust, is the trans tunnel insulation in place? What kind of insulation is under your carpet? Just some basic thoughts! Dennis
To shutoff
