[C2] Shims for starters ?
Old Jun 3, 2025 | 08:52 PM
riggsjr's Avatar
riggsjr
Default Shims for starters ?
I took my starter out of my 66 today and noticed one very very slim shim.It did not look like it was doing anything. My question is is this shim doing anything. I went to a cruise night tonight to walk around and mentioned to someone and they said every car that came off the production line had a shim from the factory.I wonder if the person before me who restored the car put it in there for judging? Does anyone know?
Old Jun 3, 2025 | 09:02 PM
R66's Avatar
R66
I have taken apart more than 10 SBCs and only found a shim under 1 starter. I doubt GM would have spent the money to shim every starter.
Old Jun 3, 2025 | 10:10 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I've had to shim an aftermarket starter but never a stock Shev-a-lay starter. Further, unlike Ron, I've never disassembled an SBC and discovered a shim.
Old Jun 3, 2025 | 10:11 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Been decades so my memory is rather non-specific, but measuring for shimming starter installation was something we 'knew' to do back in the day.
Old Jun 3, 2025 | 10:20 PM
R66's Avatar
R66
I have had to use shims when I installed a new or rebuilt starter as the bendix gear stuck in the flywheel. If you found a shim and are going to reuse the starter you took off, I would use it for reinstallation. There are threads from the past on measuring the clearance using a paper clip.
Old Jun 3, 2025 | 11:02 PM
jforb's Avatar
jforb
Measuring using a 1/8" allen wrench (between outer edge of ring gear tooth and starter shaft, you want it to fit in, but not be able to twist it) is a common thing to have done with Chevy starters...if it's too tight, add full shims as needed, if it's too loose, ad half a shim at the outboard side as needed.
but I wasn't around long enough ago to know what Chevy did in the 60s with shims.
Old Jun 4, 2025 | 09:48 PM
John S 1961's Avatar
John S 1961
I have added shims when I replaced a starter and it was obviously grinding or not running smoothly and loud too. Added a shim and then nice and quiet and smooth. Depends on tolerances. Some are too tight some are just right.
Old Jun 5, 2025 | 07:14 AM
riggsjr's Avatar
riggsjr
Well the starter is back in. No shim at first. I thought I was hearing a scrapping noise after disengaging. I added the slim back and it sounds better. Thank you everyone for your responses.
Old Jun 5, 2025 | 07:21 AM
R66's Avatar
R66
Thanks for the closure note on the thread, most like to know of your completion of the task. Some leave us hanging!!!
To Shims for starters ?
