Priceless? Worthless?
Now once this engine is in a car sitting at a car show and some 396 expert comes up and points out it is actually a 396, say, YEP, want to race! HA, have to have some fun with it.
IF my math is right: 2" pipe radius is 1 inch. 11 feet is 132 inches. Volume is pi x radius squared x height (or length). So 3.1415 x 1 x 1 x 132 = 414.7 Cubic inches.
1 US gallon is 213 cu in.
So about 1.79 gallons extra, which is still a big help, can get you several extra laps depending on the track and consumption rate.
with your help I think I’ve come up with a logical explanation for my mystery block.
1) In 1966 the Towanda plant in NY receives a 427 cast block to machine. They bore it @ 4.251 inches and deck it, but it mistakenly gets put with 396 blocks for stamping. It receives the 396 stamp of 3855962 and T1007EJ.
2) In 1966 the Fremont plant in CA puts in an order for 396 blocks from Towanda to put in their Chevelle’s.
3) Towanda stamps the misstamped 427 block with 6Z08727 designated for a Chevelle in Fremont.
4) Fremont receives their order of blocks but during assembly discover that this 396 block is actually a 427. What to do with it? Like Amazon of today GM of yesterday takes the hit and moves on. They aren’t going to send the block back to be decked and re-stamped correctly.
The fact that my block is a virgin 427 has not been in question in my mind because after two machine shops inspected, measured, and determined it is a 427 I had it sonic tested for cylinder wall thickness, (besides passing the pencil test) and the measurements confirmed it is a 427.
so to come full circle, my initial title to this thread, “Priceless? Worthless”, stands. This 1966 VIRGIN 427 block is priceless because it’s probably the only one in the world, but it’s relatively worthless because it’s not the correct 396 for the car it was stamped to go into.
Anyone interested in a very expensive, one off, rare block to be used as a single pedestal for a glass top dining table/conversation piece?
Thanks for you help.
because of the “962” casting they would not have bored it to “427”, but even if GM did, it would still appear to be a bored-out 396 because the “962” block was designed and cast to be a 396.
2)Fremont assembly plant did not put in orders for bare blocks. They put in orders for fully assembled engines. The “1007EJ” was stamped at Tonawanda, and indicated the engine ( long block) had the specified parts for a 360hp/manual transmission with A.I.R. ( California K19 smog).
3) the “Z08727” stamping was NEVER stamped by/at Tonawanda. That stamp, which should read “Z108727”, was stamped AT Fremont on the vehicle assembly line to correspond to a specific Chevelle on the same assembly line.
4). As noted, Fremont did not use bare blocks, and did not assemble engines.
and Tonawanda, if a mistake was made, would have stamped the correct coding over the previous. Of course, the 962 block would not have been used for a 427.
So you believe two mistakes were made.
Measurements will only confirm what it is now. Not what it originally was.
and regardless of what you think was the original size, it will always be a “396 block”, regardless of having a alleged “virgin” 427 bore….
otherwise, why did Chevrolet use different casting numbers for 396 and 427? Chevrolet knew there was a potential overheating issue with the 961/962 blocks bored to 427 specs. GM would not have risked the possible warranty issues.
Not worthless, but not worth as much as another 962 with less overbore.
FWIW, I have run several 962 and even a 961 2-bolt block with a 427 bore. Usually not an issue if sonic checked first.
BTW, ever ( or almost every ) 396/car427 has the “ Hi Perf” casting text. I run into a lot of people that think it’s special because it says “ Hi Perf”
Is there a detailed description somewhere of the foundry process that was used to make these parts? If so, it might explain why things are the way they are
