[C2] Stupid basic question headlight motor
Old Aug 23, 2025 | 05:12 PM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default Stupid basic question headlight motor
I want to get my headlight motors out to rebuild them.
Step 1 is to remove the plug from the motor.
I cant get the plug out! I squeeze the tab but the plug won't come out!
I tried a small screw driver to push the locking tab in but I can't get my hands in there to do it.
There isn't enough slack in the electric wires to get the motor out where I can really work on it.
Anyone have a suggestion.
Bud
Old Aug 23, 2025 | 08:55 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I unplugged them after I removed them from the shaft
Old Aug 23, 2025 | 11:49 PM
real550A's Avatar
real550A
Take the motor out, unplugging becomes much easier.
Old Aug 24, 2025 | 11:19 AM
Captain Bud
I read there isn't enough slack in the wires to do that.
Old Aug 24, 2025 | 11:24 AM
Nowhere Man
remove the harness from one of the clips. removing it first gives you enough room to put the connector in a better spot to unclip it.
Old Aug 24, 2025 | 09:13 PM
real550A's Avatar
real550A
There is plenty, if you have the hood off the car it's pretty easy to work on all of it.
Old Aug 24, 2025 | 11:21 PM
L78's Avatar
L78
I removed the two prop rod bolts from the hood and then reinserted one bolt in the "upper/rear" hood hole and the "lower/forward" prop rod hole. This held the hood in a more vertical position allowing addition room in front, without going through the hassle of pulling the hood (needing two people, etc.).
I also covered the radiator with a piece of cardboard, just to protect the core in case I dropped the motors or a wrench.
I had a 12' x 12" mirror, but found the reflection off the hood surface works pretty well with bright lights... A little disorienting trying to do everything backwards in the mirror...
Old Aug 26, 2025 | 07:07 PM
kts1962's Avatar
kts1962
I have experienced all the same challenges. Since I don’t have anything more than small inspection mirror, I used my iPhone. Worked pretty well once I got it propped up in a good spot.
Old Aug 26, 2025 | 07:25 PM
RoudyRick's Avatar
RoudyRick
ASE Master Mechanic
Life is always simpler if you do things the proper way and not take short cuts. TAKE THE HOOD OFF
Old Aug 26, 2025 | 07:33 PM
Nowhere Man
I never had to remove the hood. Just be careful
Old Aug 26, 2025 | 11:36 PM
anyChevy's Avatar
anyChevy
Open the hood past its lock position, stick a screwdriver through two holes when they line up and you will gain a little more room.
But its easier with the hood off and there’s less chance you’ll scratch it.
To Stupid basic question headlight motor
