distributor trouble
(pops through the carb after distributor was reinstalled.) I found some threads about the timing needing to be set to 10 BTDC instead of at 0 for checking for #1 position?
my guess is I'm a tooth out, read some threads that the distributor can only be in a certain way, makes sense for the tach cable etc.
I`ve checked the firing order and made sure the wires are in the correct spot etc,distibutor has electronic ignition but still has a coil not HEI. I know this has probably had many threads on it, would anyone have some tips etc for me to check.
it ran fine before the distributor came out and I made sure the dimple on the gear was the same position as the rotor.Engine was rebuilt but with a stock cam.
thanks for any help to steer me in the right direction!
Was your vac can position before more toward the valve cover? If so, I'd guess you're a tooth off.
I think it best to start over with finding firing point TDC for #1, and dropping it back in so that the rotor aligns to your #1 wire terminal. If you still get vapors pushed out the carb, I'd try switching the dimple on the shaft.
That makes me wonder about the shaft and if the orientation of the points plate is properly indexed to the cap terminal placement. Also possible, have you checked the point dwell? The points need to be right on the money or they will throw the timing off. A dwell meter check is best but if you don’t have one at least check with a feeler gauge to be sure they are right.
As long as you can time the distributor without the vacuum advance being blocked by the intake, try advancing the timing to 10 deg BTDC with the timing light and timing marks and see how it does. If it’s OK then you can always pull the distributor and rotate it a tooth CW and reset it and see if it looks oriented as lief.anderson93’s photo shows.
If it’s still popping and running rough, I can’t say the shaft is bad but I would be looking closely at it. You may need to cut a window in the side of an old cap under the #1 tower and with the engine at exactly #1 TDC the points should be closed but on the cusp of starting to open.
But, the OP noted that his distributor has been converted to breakerless, so none of this is germane to his question.
Live well,
SJW
Doesn’t seem to be an issue for Jtrav but now an electronic thing-a-ma-jig has been thrown into the mix.
ENGINE-ELECTRICAL 6Y-26 INSTALLATION-ENGINE NOT DISTURBED (ALL MODELS) 1. Turn the rotor about 1/8 turn in a clockwise direction past the mark previously placed on the distributor housing to locate rotor. 2. Push the distributor down into position in the block with the housing in a normal "installed" position (fig. 15i). NOTE: It may be necessary to move rotor slightly to start gear into mesh with camshaft gear, but rotor should line up with the mark when distributor is down in place. 3. Tighten the distributor clamp bolt snugly and connect vacuum line. Connect primary wire to coil terminal and install cap. Also install spark plug and high tension wires if removed. NOTE: It is important that the spark plug wires be installed in their proper location in the supports. 4. Time ignition as previously described under Tune[1]Up in Section 6.
INSTALLATION-ENGINE DISTURBED (ALL MODELS) 1. Locate No. 1 piston in firing position by either of two methods described below, a. Remove No. 1 spark plug and, with finger on plug hole, crank engine until compression is felt in the No. 1 cylinder. Continue cranking until timing mark on crankshaft pulley lines up with timing tab attached to engine front cover. b. Remove rocker cover (left bank on V-8 engines) and crank engine until No. 1 intake valve closes and continue to crank slowly about 1/3 turn until CENTRIFUGAL jS ADVANCE ROTATING POLE PIECE STATIONARY POLE PIECE MAGNETIC PICKUP ASSEMBLY VACUUM ADVANCE DISTRIBUTOR HOUSING Fig. 151—Six Cylinder Engine Distributor Fig. 16i—Magnetic Pulse Distributor Components CHEVROLET CHASSIS SERVICE MANUAL ENGINE-ELECTRICAL 6Y-27 timing mark on pulley lines up with timing tab. 2. Position distributor to opening in block in normal installed attitude (fig. 15i), noting position of vacuum control unit. 3. Position rotor to point toward front of engine (with distributor housing held in installed attitude), then turn rotor counter-clockwise approximately 1/8 turn more toward left cylinder bank and push distributor down to engine camshaft. It may be necessary to rotate rotor slightly until camshaft engagement is felt. 4. While pressing firmly down on distributor housing, kick starter over a few times to make sure oil pump shaft is engaged. Install hold-down clamp and bolt and snug up bolt. 5. Turn distributor body slightly until points just open and tighten distributor clamp bolt. 6. Place distributor cap in position and check to see that rotor lines up with terminal for No. 1 spark plug. 7. Install cap, check all high tension wire connections and connect spark plug wires if they have been re[1]moved. It is important that the wires be installed in their location in the supports. NOTE: The brackets are numbered to show the correct installation. Wires must be installed as indicated to prevent cross firing. 8. Connect vacuum line to distributor and distributor primary wire to coil terminal. 9. Start engine and set timing as described under Tune-up in Section 6.
FYI: https://www.workshopservicemanual.co...-repair-manual
If there were no vacuum cannister involved, your statement would, basically, be true. But, if you were to install the distributor cap, say, 90* clockwise from where it is supposed to be, where does that put the vacuum cannister? There is a very logical reason why the distributor and cap have to be oriented like is shown in my picture.
