1961 Corvette Rear end Code AA
Old Sep 13, 2025 | 06:23 PM
RW68RSConv's Avatar
RW68RSConv
Default 1961 Corvette Rear end Code AA
Hi all. Recently purchased a '61 and of course, the automotive archaeology begins. It isn't numbers matching anything and wasn't represented as such. I have a warmed over '66 Corvette 327 in it; the rear is clearly stamped "AA" which isn't a Corvette pumpkin that I can tell, but does code to a 3.55 open diff. My question is: Were there any special features in the Corvette housings? Heavier duty, different bearings, casing, whatever? Personally, I like the 3.55 gears and plan to swap in a 5-speed with overdrive, so it's about the perfect gear (will want to upgrade to posi - don't know how feasible that is in that old axle housing?. Anyway, just curious. Thanks.
Old Sep 14, 2025 | 09:51 AM
gsorange's Avatar
gsorange
Look for Posts by Tom Parsons. See attached PDF
Old Sep 15, 2025 | 10:00 PM
RW68RSConv's Avatar
RW68RSConv
Thanks for the link! Very helpful!
To 1961 Corvette Rear end Code AA
