[C2] Missing rubber stop
Old Sep 21, 2025 | 10:04 AM
C6Tim's Avatar
C6Tim
2025 Restomod of the Year Finalist
Default Missing rubber stop
I just noticed that the rubber stop on the drivers side hood latch has gone missing. Anyone know where I can buy a replacement without having to buy the whole latch? Thanks!
Old Sep 21, 2025 | 10:18 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Contact Zip Corvette, or any other Vette suppliers, they all have what you need. Dennis
Old Sep 21, 2025 | 10:23 AM
C6Tim's Avatar
C6Tim
Thanks, I looked online but not surprisingly no one shows the stopper as a separate part so I will take your advice and give Zip a call.
Old Sep 21, 2025 | 10:34 AM
65hihp's Avatar
65hihp
Hood Adjusting Bumper Screws are available.. Or maybe you only need the rubber cap? they are out there too.
​​​​​​https://www.zip-corvette.com/63-76-h...Gg4ODExMTMwNDI.
Old Sep 21, 2025 | 10:43 AM
leif.anderson93's Avatar
leif.anderson93
Yup, here they are...
https://www.zip-corvette.com/53-76-h...Gg5NzQ3ODMxMzI.
53-76 Hood Bumper Rubber Caps (Correct)
Old Sep 21, 2025 | 10:46 AM
C6Tim's Avatar
C6Tim
Thanks guys! Just ordered a pair, don't know how I missed them before.
Old Sep 26, 2025 | 12:55 PM
C6Tim's Avatar
C6Tim
Just got the replacement rubber stopper and was wondering how the screw it sits on should be adjusted?. I never paid much attention to them before but since noticing the rubber missing I also noticed that the passenger side screw is set much higher than the screw on the drivers side. I understand how to adjust the screw just wondering what the proper procedure is for knowing/getting it fit at the correct height.
Old Sep 26, 2025 | 01:35 PM
leif.anderson93
Install the rubber bumpers. Lower the hood to the pin stops. Gently push on each rear corner of the hood until it "clicks" shut and locked. Now, apply pressure to each rear corner of the hood with the palm of your hand. If the hood corner pushes down, the screw can be adjusted out some (not a lot...1/2 turn at a time) to compensate for the difference. Do this on both sides until you can barely push the hood down once it is sitting in it's locked position. The concept is to take out any small difference to compensate for hood vibration. A bit of trial and error.
Old Sep 26, 2025 | 02:28 PM
C6Tim's Avatar
C6Tim
Originally Posted by leif.anderson93
Install the rubber bumpers. Lower the hood to the pin stops. Gently push on each rear corner of the hood until it "clicks" shut and locked. Now, apply pressure to each rear corner of the hood with the palm of your hand. If the hood corner pushes down, the screw can be adjusted out some (not a lot...1/2 turn at a time) to compensate for the difference. Do this on both sides until you can barely push the hood down once it is sitting in its hunks!locked position. The concept is to take out any small difference to compensate for hood vibration. A bit of trial and error.
Thanks!
To Missing rubber stop
