moving problem
Old Oct 3, 2025 | 06:41 PM
Guinness1's Avatar
Guinness1
Default moving problem
will be moving my c2 on car trailer but he has no wheel straps how do i secure the back end
Old Oct 3, 2025 | 06:54 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Put straps around the ends of the spring
Old Oct 3, 2025 | 07:07 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
The spring is stronger at the differential. If I had to wrap straps around the spring to secure the back end, that's where I'd attach them.
Old Oct 3, 2025 | 09:02 PM
R66's Avatar
R66
I would put straps around the trailing arms close to the shock absorbers and cross the straps to prevent lateral movement. In the front, around the a-frames and also cross the straps. A fifth strap from the cradle in the front to the tongue of the trailer. But I always go overboard after I lost a newly painted Camaro off of the trailer when the chain hooks came loose. Luckily it was when leaving a stop light on the way to Indy to race.
Old Oct 3, 2025 | 09:08 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I always put a short strap through the front a arms and over the rear axle, then grabbed them with a long strap, crossed.
Old Oct 4, 2025 | 05:59 AM
Argentimage's Avatar
Argentimage
Just a bit of advice from the Oem world
you do not strap down the suspension
The reason is is you have all that weight, flexing, vibrating, on the wheel bearings
That was happening and premature failure of wheel bearings peening the race surfaces was noted on brand new vehicles
failure a thousand miles later
Better to find a trailer you can strap down at the wheels
Old Oct 4, 2025 | 06:31 AM
65GGvert's Avatar
65GGvert
There are tie down slots in the frame that the factory used to transport C2's, using J hooks or T hooks.
To moving problem
