Clock Stops When headlights Turned
Old Oct 6, 2025 | 11:10 AM
SeniorL79's Avatar
SeniorL79
Default Clock Stops When headlights Turned
Noticed today that when I turn on my headlights the clock stops running.
Thoughts?
Old Oct 6, 2025 | 01:56 PM
ChrisBlair's Avatar
ChrisBlair
Aftermarket clock?
Anything else electrical aftermarket?
Old Oct 6, 2025 | 02:34 PM
SeniorL79's Avatar
SeniorL79
No, original clock from 1967. Did have the cars complete electrical harness replaced. Harness from Lectric Limited.
Old Oct 6, 2025 | 02:36 PM
ChrisBlair's Avatar
ChrisBlair
And it worked prior to the install? When was this?
Old Oct 6, 2025 | 02:39 PM
65GGvert's Avatar
65GGvert
Thoughts?
The stock clock doesn't run on electricity. It's a mechanical clock that's rewound every couple minutes by relay so I don't think your headlights have anything to do with the clock stopping. If you're sure it's a stock clock from 67.
Old Oct 6, 2025 | 03:18 PM
SeniorL79's Avatar
SeniorL79
Install was done early summer 2025. Car is registered as an antique so I can't drive it (legally) after dark which is why I never noticed the problem before today.
Old Oct 6, 2025 | 03:19 PM
SeniorL79's Avatar
SeniorL79
Could the new electrical harness installation affect it?
Old Oct 6, 2025 | 03:22 PM
leif.anderson93's Avatar
leif.anderson93
No, not the way you're describing the problem...re-read post #5.
Old Oct 6, 2025 | 03:33 PM
65GGvert's Avatar
65GGvert
I suspect your clock may have been changed over to a quartz clock before or during the restoration. If you find that to be correct, make sure the ground connection on the clock is good. With a stock clock about every two minutes or so you'll hear a loud click when it rewinds
If you disconnect the battery, the clock will continue to run until time for the rewind. If it has been switched to a quartz clock when you disconnect the battery, the clock will stop so you'll know for sure.
Old Oct 6, 2025 | 03:35 PM
SeniorL79's Avatar
SeniorL79
Baffling, I need to do more research.
The only time I've ever noticed the clock stopping is when I turned on the headlights.
Old Oct 6, 2025 | 03:40 PM
SeniorL79's Avatar
SeniorL79
Thanks for the info, I'll follow the procedure to make sure the clock has not been switched out to quartz.
Old Oct 6, 2025 | 04:04 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Pretty sure that relay is reset by electricity. I still don't know how the headlight switch could affect that connection.
Old Oct 6, 2025 | 05:36 PM
SeniorL79's Avatar
SeniorL79
So, after speaking with the fellow who did the restoration the clock is original but was rebuilt with a quartz movement at some point.
He's going to check wiring diagram for a fix.
Thanks for every ones help, us newbies would be lost without it.
Old Oct 6, 2025 | 06:39 PM
65GGvert's Avatar
65GGvert
as I said, it only uses electricity once every couple of minutes for a fraction of the second.
Old Oct 6, 2025 | 06:42 PM
65GGvert's Avatar
65GGvert
I don't think a wiring diagram is gonna help you. There's only two wires 12 V and ground. the only thing that would affect the clock when you turn the headlights on as if the clock didn't have a good ground or it was dropping the battery voltage too low to operate the clock, which is very unlikely. Put s voltmeter on the 12 V lead on the clock and turn the headlights on and see what the voltage does and report back.
Old Oct 6, 2025 | 07:41 PM
joewill's Avatar
joewill
so according to OP the clock was restored with a quartz movement.. which means it needs constant electricity.. unswitched electricity.
Looking at my 67 wiring diagram: unswitched electricity is the clock, headlights, brake lights, horn, glovebox lights and cigar lighter..
unswitched electric connection occurs when turning on the headlights which turns on the instrument panel lights.. and the clock lights..
by unswitched, I mean you don't have to turn the key on to use these functions
are any of these functions effected by the headlights being turned on?
Old Oct 6, 2025 | 07:55 PM
62Jeff's Avatar
62Jeff
Yes, I had this exact problem on my 1971 Olds Vista Cruiser when I installed the quartz clock. Turning on the headlights caused the clock to stop. Adding a new, dedicated ground wire solved my problem.
Old Oct 8, 2025 | 10:26 AM
blitz10's Avatar
blitz10
My clock did the same on my 67. It has a Quartz clock. I had the car worked on and the problem started afterwords. Turn on the lights and the clock stopped. Took out clock and found that 1 spade on the connector had pushed back and was not making a connection. Pushed the spade back in position and all was fine. I also made an extension on the clock harness to make it easier next time.
Old Oct 11, 2025 | 11:55 PM
65GGvert's Avatar
65GGvert
So, did you try grounding the clock?
To Clock Stops When headlights Turned
