Freon question
Old Oct 10, 2025 | 05:35 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Freon question
Can you use HC-12A with R12
Old Oct 10, 2025 | 05:43 PM
leif.anderson93's Avatar
leif.anderson93
Keith,Here’s the short answer:
HC-12a can be used as a replacement for R-12, but there are some important caveats.
🔧 Compatibility
  • HC-12a is a hydrocarbon-based refrigerant (mostly propane/isobutane blend).
  • It is compatible with the mineral oils used in R-12 systems, so you usually don’t have to change the oil or make major system modifications.
  • You must completely recover all R-12 before adding HC-12a — you cannot mix them. Mixing R-12 and HC-12a can cause pressure and lubrication problems and is illegal under EPA rules.
⚠️ Legal and Safety Considerations
  • HC-12a is not EPA-approved for use in automotive A/C systems originally designed for R-12 or R-134a in the U.S. (it’s considered a “flammable substitute”).
  • It’s legal in some off-road, agricultural, or stationary refrigeration uses, but not in on-road automotive A/C under current EPA regulations.
  • It’s flammable, so extra caution is needed during charging and servicing.
⚙️ Practical Use (if legally permitted)
If used in a setting where it’s allowed:
  1. Recover all R-12 (don’t vent it).
  2. Evacuate the system completely.
  3. Charge with about 35–40% of the original R-12 charge by weight (HC-12a operates efficiently at lower pressures).
  4. Label the system clearly as containing HC-12a.
Old Oct 11, 2025 | 09:45 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Given you must evacuate an R12 charged system prior to charging with HC-12A I recommend using 134A even if that means the minor hassle of changing the oil to ester (poe), which can be used with R12 or HC-12A should you decide to go with it later.
Why? Because to my knowledge no AC shops have a recovery rig for HC-12A and don't want to contaminate the rig they have. Few have an R12 rig. Everybody has a 134A rig though those will begin to disappear now that 1234YF is here and which is flammable don't you know.
134A will cool as well as R12 in a system otherwise in perfect operating condition. I have 6 air conditioned antiques to prove it. Properly charged into a tight, dry, deep vacuum 134A will function indistinguishably from R12 (or HC12A). It will make your life easy. If your system is tight, you won't need to worry about it. I have a 62 Bonneville, same system as a Corvette, running the same 134A charge since 2008 and it blows 38F.
Dan
Old Oct 11, 2025 | 10:13 PM
Nowhere Man
the only reason for the question was we found some of the HC 12A local for cheap. and wondering why it was cheap. but it seems its clear.
Old Oct 12, 2025 | 02:32 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I solved the problem.
MANY years ago (when I saw the writing on the wall), I started accumulating R12. Now I have an R12 inventory that will long out last me! Several tanks and a few cases of 12 cans.
To Freon question
