[C1] Speedometer issues
Old Oct 31, 2025 | 10:58 AM
Buzzz's Avatar
Buzzz
Default Speedometer issues
My 1961 speedometer has suddenly gone haywire. The speed part is still working, but it’s making a clicking noise and the needle is kind of bouncing. The odometer has stopped turning. Anyone else ever run into this and anyone know what the problem could be?
Old Oct 31, 2025 | 03:27 PM
mrtnfischer's Avatar
mrtnfischer
JUST had mine doing the same on my '62, I had the cluster removed, had a new odometer gear and numbers replaced by Mike Freeman in Greer SC, (he redid the speedo and put the numbers inside) than went to put it all together,. went to replace the gear in the transmission and the old one fell in side the trans, Now I am in the process of taking the drive shaft down, removing the transmission mount, removing the tail stock, fishing for the gear. Hope I can find it. and replace everything. So Be careful
Old Oct 31, 2025 | 07:55 PM
Buzzz's Avatar
Buzzz
yikes! So did you try it once the cluster was redone? It sounds like the problem was the gear on the transmission?
Old Nov 1, 2025 | 12:34 AM
silver837's Avatar
silver837
I lost the plastic gear in my T-10 years ago . I replaced it with no side effects . It's still in there .
Old Nov 1, 2025 | 11:06 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Yeah, the tailshaft housing has a big open chamber in it. I don't see a big deal there. Leave it and move on..
To Speedometer issues
