[C2] 63 steering column
Old Dec 30, 2025 | 12:21 PM
Whatscooking's Avatar
Whatscooking
Default 63 steering column
I have the complete column out. Noticed notchey motion not smooth. Can I loosen the clamp on the lower and pull the shaft out without destroying anything up top?
Old Dec 30, 2025 | 04:31 PM
tbarb's Avatar
tbarb
Yes, remove the lower clamp and carefully lift the hub and shaft out from the top, be careful with the cancelling cam and it's clocking position when you reassemble. Carefully inspect the lower steering shaft for grooves and the lower bearing.
Old Dec 30, 2025 | 04:47 PM
Whatscooking
To 63 steering column
